radiator j fan plate astra 13 sri
Astra J SRI 13 Plate - Radiator Fan
Good evening guys,
looking to see if anyone can help with a problem i have with my 13 plate Astra J SRI,
For a while the radiator fan was staying on (common issue i know), i didnt do anything about it until recently,
I have replaced the thermostat and housing, the temperature sensor, checked that all the fuses are intact, removed the sensor from the air filter and still nothing from the fan,
I kept getting the message "coolant level low - add Coolant" i replaced the expansion tank and now ok,
I have seen that there could be an issue with the relay? unsure which one it is as its not mentioned in the handbook,
I have also ordered test leads to see if the fan works when i connect to the battery...
coming a bit unstuck now and just wondered if anyone had any other ideas i could try before i put it into the garage?
Gavin
This may help with the relay looking up.
https://www.vxoc.org.uk/forum/Thread-Fuses
(9:th-Jul-2020, 07:18:49)Rusty2009 Wrote: This may help with the relay looking up.
Many Thanks, ive ordered new relays so will try that out... if not i will test the fan and see if its that,
Thanks for the reply, will report back,
  Astra J 2014 1.6 petrol, dashboard noise help Steve1982 0 963 9:th-Sep-2025, 08:39:49
  Astra J 2014. Electric static noise under dash Steve1982 0 910 8:th-Sep-2025, 21:22:49
  2010 Astra J - Cooling Fan issue Madal101_uk 3 3,830 19:th-Dec-2024, 22:04:08
Last Post: Madal101_uk
  High pitched noise (Astra OPC J) maximame 0 6,922 24:th-Mar-2021, 08:34:13
Last Post: maximame
  Gear Knob issue (Automatic 2014 Astra GTC) DC23 1 8,079 22:nd-Feb-2021, 08:08:37
  Astra J. Can a tyre valve be replaced without replacing the TPMS? benawhile 2 7,732 5:th-Aug-2020, 12:33:14
Last Post: benawhile
  Astra GTC auto gear knob replacement Jayrich872001 12 31,331 22:nd-Jul-2020, 12:21:46
Last Post: DC23
  Astra J 1.6 CDTi increased fuel consumption _Mita 2 11,589 1:st-Mar-2020, 22:27:38
Last Post: _Mita
  Astra ST 1,6 CDTi, error code P0181 claymansvk 1 5,684 20:th-Feb-2020, 19:32:31
  shock absorber noises astra j blacknik 1 7,347 10:th-Feb-2020, 08:34:15
