20:th-Jan-2019, 23:39:42
hi is retrofitting a Nav950 ieasy enough and can i keep my DAB and USB (currently have cd400)
| 950 nav |
Nav 950
22:nd-Jan-2019, 17:25:56
Easy if you can program it and know the wiring changes needed.
in regards with the USB the USB goes directly into the back of the radio rather than via the module. If fitting a Navi950 2 data wires need adding to the DAB module so it functions and it has to be the U4D DAB module. Astra-J 2.0 CDTI S/S
22:nd-Jan-2019, 21:08:24
(22:nd-Jan-2019, 17:25:56)Rusty2009 Wrote: Easy if you can program it and know the wiring changes needed. cheers Rusty at the moment i am torn between an android unit or holing out for a genuine nav unit if i go fro the nav unit what the price for fitting and coding ?
24:th-Jan-2019, 08:19:13
(22:nd-Jan-2019, 21:08:24)caspyrp Wrote:(22:nd-Jan-2019, 17:25:56)Rusty2009 Wrote: Easy if you can program it and know the wiring changes needed. Cost to fit & code is £280. Astra-J 2.0 CDTI S/S
24:th-Jan-2019, 09:51:52
a few owners have replaced their aftermarket radios with the Navi950 because it's so much better
24:th-Jan-2019, 22:31:31
25:th-Jan-2019, 08:34:27
They are hard to come by when you see one grab it.
£320 on ebay - https://www.ebay.co.uk/itm/VAUXHALL-ASTR...SwRWZcPA1h
27:th-Jan-2019, 20:23:15
(25:th-Jan-2019, 10:14:08)vocky Wrote: £320 on ebay - https://www.ebay.co.uk/itm/VAUXHALL-ASTR...SwRWZcPA1h i did see that one but wasn't sure about the screen ? bit curious why it was missing the fascia
27:th-Jan-2019, 20:49:51
(This post was last modified: 27:th-Jan-2019, 20:56:45 by marktourino.)
(27:th-Jan-2019, 20:23:15)caspyrp Wrote:(25:th-Jan-2019, 10:14:08)vocky Wrote: £320 on ebay - https://www.ebay.co.uk/itm/VAUXHALL-ASTR...SwRWZcPA1h I presume it the fascia that goes round the screen.
27:th-Jan-2019, 21:51:42
(27:th-Jan-2019, 20:49:51)marktourino Wrote:(27:th-Jan-2019, 20:23:15)caspyrp Wrote:(25:th-Jan-2019, 10:14:08)vocky Wrote: £320 on ebay - https://www.ebay.co.uk/itm/VAUXHALL-ASTR...SwRWZcPA1h
28:th-Jan-2019, 08:29:33
yes they have taken the screen surround off, you can buy them from gps or dealer.
13:th-May-2019, 13:07:41
Hi I’ve just added a dab unit u4d module to my navi950 but nothing do I need to do a update ?
14:th-May-2019, 06:31:09
(13:th-May-2019, 13:07:41)Rikfields1971 Wrote: Hi I’ve just added a dab unit u4d module to my navi950 but nothing do I need to do a update ? Yes the radio needs programming so it knows it has DAB. Vauxhall will charge you £175 in programming costs alone. I charge £110 via the post. Astra-J 2.0 CDTI S/S
