complete sat nav system
http://www.ebay.co.uk/itm/2013-GENUINE-V...43d933ebe8
Surely this would be a straight swap if it has everything needed?
Sat nav Update info
Sat Nav update discs.
When purchased they are sold as Hardware and Software.
The hardware is the update of the Sat Nav, A New Firmware version.
The Software is the Map Program itself.
How to install a Map Update (The manual isn't clear on this and no instructions are given with the disc)
1. Insert the New Map CD into the CD player.
2. The screen will show that there's an update for the firmware.
3. Click Install.
4. It will ask if you wish to over write the Flash in the memory, click okay to do
How to install Sat Nav to a safe location
This little gadget seems too obvious for me to post it online and technically it isn't a 'how to' guide. However, I'm sure there are drivers on this forum who may just have overlooked this idea so I'm posting it in case it helps someone.
Instead of having your TomTom stuck on the windscreen in your face, there is a 'gooseneck' available, some made my TomTom themselves and others that are after market. Mine is an after market one and may do the job better because as far as I know it is slightl
NAV 600 SD CARD
NAV 600 SD CARD
GRATE BRITAIN AND IRELAND
2011 2012 MAPS..
FULLY WORKING ORDER......NO CASE...
WORKS ON ALL VAUXHALL CARS WITH THE NAV 600...
£29.99 POSTED....
[Image: http://i179.photobucket.com/albums/w301/...iq7d8r.jpg]
Updating Bi Turbo Sat nav
I think my sat nav needs updating. How do I go about that?
Is it a trip to the dealer?
Cheers peeps
@Tucpal @hev - sorry mate i couldnt reply to the other thread but i think the only way to update the 950 is to take it in for a software update which apparantley they only do 2-3 times a year as the navi 950 doesnt have an sd card that you can access. If it uses one its probably built in or behind it which you'd have to take it all apart to get too.
2011 Astra SRI CDTI 125, nav, 19" wheels, full MOT, serviced
https://www.ebay.co.uk/ulk/itm/201541144132
Offers very welcome, I'm not sure what it's worth so comments on value are welcome!
Installing 2013 intellilink nav unit and trim on a 2010 Insignia
Hey guys!
I am interested in fitting an intellilink nav unit from the 2013 facelift Insignia on my 2010 Insignia.
Essentially, I want to go from the one on the left to the one on the right:
[Image: http://www.auto-news.de/webcore/data/con..._3_big.jpg]
(image take from: http://www.auto-news.de/webcore/data/con...rticle_EXT)
I am not really intere
sat nav antennas
Are there different sat nav antennas?  i mean i imagine they will be different for the different cars, but do they all work the same?
[attachment=976]
I pulled this one off an astra in the scrappers, not sure what radio it had as it was gone,  but the antenna has 3 connections... all those fakra types... so i presume it's got fm, dab and sat nav?
[attachment=977]
i pulled the antenna wires out best i could... was weird how they were all three together till the drivers seat,  then o
Nav 950
hi is retrofitting a Nav950 ieasy enough and can i keep my DAB and USB (currently have cd400)
