950 nav
Nav 950
hi is retrofitting a Nav950 ieasy enough and can i keep my DAB and USB (currently have cd400)
Easy if you can program it and know the wiring changes needed.
in regards with the USB the USB goes directly into the back of the radio rather than via the module.
If fitting a Navi950 2 data wires need adding to the DAB module so it functions and it has to be the U4D DAB module.
(22:nd-Jan-2019, 17:25:56)Rusty2009 Wrote: Easy if you can program it and know the wiring changes needed.
cheers Rusty
at the moment i am torn between an android unit or holing out for a genuine nav unit if i go fro the nav unit what the price for fitting and coding ?
cheers Rusty
Cost to fit & code is £280.
a few owners have replaced their aftermarket radios with the Navi950 because it's so much better
(24:th-Jan-2019, 09:51:52)vocky Wrote: a few owners have replaced their aftermarket radios with the Navi950 because it's so much better
had a look around and  no 950 unis  on ebay ?
do they come up often are are they a rare commodity
They are hard to come by when you see one grab it.
£320 on ebay - https://www.ebay.co.uk/itm/VAUXHALL-ASTR...SwRWZcPA1h
(25:th-Jan-2019, 10:14:08)vocky Wrote: £320 on ebay - https://www.ebay.co.uk/itm/VAUXHALL-ASTR...SwRWZcPA1h
i did see that one but wasn't sure about the screen ?
bit curious why it was missing the fascia
I presume it the fascia that goes round the screen.
i tried to ask the seller if they had the fascia but there not taking messages from ebay so probably going to wait for a complete kit
yes they have taken the screen surround off, you can buy them from gps or dealer.
Hi I’ve just added a dab unit u4d module to my navi950 but nothing do I need to do a update ?
(13:th-May-2019, 13:07:41)Rikfields1971 Wrote: Hi I’ve just added a dab unit u4d module to my navi950 but nothing do I need to do a update ?
Yes the radio needs programming so it knows it has DAB.
Vauxhall will charge you £175 in programming costs alone.
I charge £110 via the post.
