clutch
Clutch
(23:rd-Feb-2017, 18:58:04)sheppy1 Wrote: Don't suppose it applies to the 1.7 too does it?
No just to the 2.0cdti with the F40 gearbox and A20 Dth engine.
my 2.0 cdti has developed a fault. when I accelerate in 5th and 6th , it gets to around 60-70 then sometimes its as if ive pressed the clutch in. the engine loses power and over revs like its not in gear??
If I let off for a few seconds then its normally ok. other times I have no problems?
(3:rd-Oct-2017, 19:27:43)r6sporty Wrote: Hi, are you aware of any other issues with the clutch?
Had this in my old car. Was the start of my clutch going
Your clutch is slipping
Got car in for service on Wednesday and mentioned this bulletin... they going to look into it.
Cheers op ??
I've had the car for two years now, clutch hasn't gave me any bother other than the knocking sounds in second and third. I clearly don't have warranty anymore, but how would I go about bringing the bulletin to the attention of Vauxhall?
Would they still fix it, the car is only 6 years old.
(8:th-Jan-2021, 23:25:40)14PGTC Wrote: Mine knocks in second and third gear, not so much in other gears. Also, if I was to accelerate and let off and put the clutch in, the whole car would shake.
When  you speak to them tell them you have a bulletin number.
As to weather it would still be covered is something you would have to argue about with the dealership/ vauxhall.
Be warned they are very good at wriggling out of things.
Jordan_Sparkes (7:th-Mar-2025, 01:57:04)
