![[Image: vx.o.c.jpeg]](http://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Logo/vx.o.c.jpeg)
How to add your photographs to the forum using Photobucket.
You want to include photos into your threads / posts on VX.O.C.
The best way to do this is via an image hosting site, this keeps the sites sever space down and allows you more control over your photos.
I recommend using Photobucket to host your photos, registration is required and you can set your own privacy settings. Photobucket is free & easy to use and offers many features you can if needed buy extra space, or by using there apps you can gain more free space.
1. Go to Photobucket
![[Image: Photobucket.png]](http://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Help%20section/Photobucket/Photobucket.png)
2. Click the sign up button highlighted
![[Image: Photobucket1.png]](http://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Help%20section/Photobucket/Photobucket1.png)
3. Fill in the form, this form needs your email address, a username (Username will be displayed in address links and cannot be changed so choose carefully), password, date of birth, *** & postcode.
![[Image: Photobucket2.png]](http://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Help%20section/Photobucket/Photobucket2.png)
4. Slide the arrow across so they know you are human.
5. Then click the "Get started" button at the bottom.
![[Image: Photobucket3.png]](http://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Help%20section/Photobucket/Photobucket3.png)
6. It will then say "Welcome to Photobucket.
![[Image: Photobucket4.png]](http://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Help%20section/Photobucket/Photobucket4.png)
7. To upload just click the "UPLOAD" button at the top.
![[Image: Photobucket5.png]](http://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Help%20section/Photobucket/Photobucket5.png)
You can now browse to pictures or you can simply drag and drop them.
If you want to browser then click the âchoose photos and videosâ button and it will open up a box (like adding an attachment to an email or saving a file from the web).
Once you have browsed to the folder where your pictures are you can then select just one or multiple images. To select multiple images simply hold down the ctrl button on your windows keyboard and then left mouse click the images you want to upload.
![[Image: Photobucket7.png]](http://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Help%20section/Photobucket/Photobucket7.png)
Once done click the âOPENâ button and the upload will begin.
You can name the photos underneath each upload if you like.
![[Image: Photobucket9.png]](http://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Help%20section/Photobucket/Photobucket9.png)
8. Once the photos are uploaded click on the âView Uploadsâ button at the top under âYour Bucketâ
![[Image: Photobucket10.png]](http://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Help%20section/Photobucket/Photobucket10.png)
![[Image: Photobucket11.png]](http://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Help%20section/Photobucket/Photobucket11.png)
Click on one image to open it in full view and get access to the links or you can just hover over the image and when a little cog appears in the top right comer hover on it and then drop down to âget linksâ and click it.
![[Image: Photobucket12.png]](http://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Help%20section/Photobucket/Photobucket12.png)
![[Image: Photobucket14.png]](http://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Help%20section/Photobucket/Photobucket14.png)
Once the popup comes up you need the direct link, just click on it and it will flash yellow & say copied.
Or as mentioned above large view method, click on the image and it will open.
![[Image: Photobucket16.png]](http://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Help%20section/Photobucket/Photobucket16.png)
You can skip though images using the arrows on the left, right or above.
Again you just click the direct box and it will flash yellow and say copied.
From here you can add them into your thread / post, by using the [img]""[/img] tags.
Example "[img]your link will go here[/img]"
That's it all done enjoy sharing your pictures with the rest of the VX.O.C members.
