up blow valve tyler
Tyler valve blow up
As you can see from picture it blow off and all the thred is still in the valve cap .
Looks fooked
totaly
They could just change the stem you can buy kits.
Hi all I had a new one fitted at a cost dam vauxhall, still have a flat tyre warning on dash tho.
Is the pressure showing for the valve? If not and if doesn't wake up after a drive it needs waking up with the tool.
I took it back to vauxhall and they did something no warning now. Pluses the did the fuel filler cap wax thing.
  Fuel Shutoff Valve NuttySqurill 1 3,475 12:th-Aug-2020, 07:58:08
  Cracked tyre valve with TPMS Craig2305 5 7,325 5:th-Oct-2018, 13:31:48
Last Post: Craig2305
  Dump Valve jamoes009 1 5,568 17:th-Mar-2017, 23:00:19
Last Post: Wayneofwolves
  EGR VALVE, MAP SENSOR, MAF SENSOR, THROTTLE BODY NEED TO IDENTIFY caretaker 2 7,815 16:th-Aug-2016, 15:22:22
Last Post: caretaker
  Recirculation valve for 1.6 turbo SRI SI SRI 3 10,200 31:st-Jul-2014, 20:28:54
Last Post: Cameron UK
  Corsa VXR dump valve SI SRI 3 7,398 26:th-Jul-2014, 17:43:45
Last Post: SI SRI
  dump valve and boost guage Dicko 3 7,729 28:th-Jun-2014, 18:22:49
Last Post: Lush Lighting City
  Dump valve for Astra J 1.6 Turbo SI SRI 0 6,955 8:th-Jun-2014, 22:23:20
Last Post: SI SRI
  Cdti dump valve richje100 4 11,250 8:th-May-2014, 10:43:41
Last Post: cornishtaz
