to in post unable electrical
Unable to post in electrical
For some reason I cannot reply to threads in the electrical section of the forum... the is no 'reply' tab on each post or 'new reply' tab under the last post?
Any reason for this?...
Take a look later on
In fact, it looks as though it is the same for me throughout the technical section.
There was an update the other day something must not be working correctly
It's been like that for quite some time now, at least 2 or 3 months I believe, I just thought it was an administration thing but I've noticed others posting so I thought I'd better bring it up as others might have tried and thought the same as me.
Thanks for bringing it up
It's the whole technical section, I've never had access.
it may be locked to unpaid members rusty will have to confirm this as i get in there no problem
I will look into all should have access
(13:th-May-2016, 09:37:48)stigeye Wrote: For some reason I cannot reply to threads in the electrical section of the forum... the is no 'reply' tab on each post or 'new reply' tab under the last post?
I've checked the permissions and you should be ale to post.
Can you PM your password so I can look into for you.
(13:th-May-2016, 19:55:05)Rusty2009 Wrote: Can you PM your password so I can look into for you.
PM sent
Should all be working for you now.
Yes mate, just had a quick look and the reply tabs are all there
Users browsing this thread: 17 Guest(s)
