Electrical connection for camera
I've got a 2014 Astra estate I'm wanting to install hardwire my dash cam and wondering on the best and easiest method
I've had the glove box out and the trim in passenger footwell etc but came a bit stuck when I tried to remove the pillar trim to run cable up the side of the windscreen and along head lining to camera located just behind rear view mirror, so the idea I've had is to possible tap off the interior light, is this easy to remove to get at the wiring? I'm an electrician by trade
Unable to post in electrical
For some reason I cannot reply to threads in the electrical section of the forum... the is no 'reply' tab on each post or 'new reply' tab under the last post?
Any reason for this?...
[Image: https://gyazo.com/57c3d9d74d96f81343bca8bf533e9f64.png]
electrical rear windows
Because with the cluster i didnt sort it out and the money wanted to be spend ive manage to buy all the parts for rear electrical windows
I`ve tried to find info and i saw that i need to have pins in the rear pillar like 1,10, 15 and the pins on fuse 20 from engine. I have them all. And now because i didnt find more infos..question is : if i have all the pins already fitted i need any extra cables from rear/front doors to bcm ?
