headlight swap
Headlight Swap
I have an Astra J 5 Door elite with halogen headlights and normal Halogen DRL’s , does anyone know if I could swap the headlights for the factory halogen with LED drls, would it be a straight swap or would it have to be programmed into the car, thanks
Yes it is possible. The main headlamp connector is the same.
After the change the DRL error appear on the dash board. Of course, LED DRLs have lower current consumption. That's what I expected.
The vehicle BCM cannot be reprogrammed unfortunately. But I didn't expect that. :-( .
I tried and I tried but couldn't found a nice solution.
At the end I added a resistor on the DRL wire an solve it. Not nice but it's working.
Is the dimming function working as it should be (day/night mode)?
Yes, everything works fine.
Except "DRL error" mention earlier.
You can program the BCM with a VCI code which GM should supply, but I can't remember what price cat it comes in.
Of course there are other-ways around it but not as simple.
Fitting a resistor is the cheapest option.
(8:th-Dec-2019, 08:59:04)Rusty2009 Wrote: You can program the BCM with a VCI code which GM should supply, but I can't remember what price cat it comes in.
I am in the same situation after drl led headlights swap. I would like to sort that errors out without fit resistors
Would require either a VCI code or custom programming to change the DRL to LED.
  Headlight bulbs on a 16 GTC Limited Ed SMS19 1 8,287 14:th-Aug-2020, 14:38:50
  Headlight bulbs Flick19191 2 8,255 25:th-Sep-2019, 08:25:23
Last Post: Flick19191
  Astra J 2012 5 door HEADLIGHT + SIDELIGHT BULBS LukeAstra15 17 24,118 7:th-Oct-2017, 08:02:02
Last Post: umognog
  Which part is missing ? (Headlight) Sero6262 2 10,271 31:st-May-2017, 09:29:41
Last Post: stigeye
  New Headlight Query stigeye 5 12,362 3:rd-Nov-2016, 00:04:09
Last Post: stigeye
jas7c5-2008 (25:th-Dec-2025, 18:17:41), Andys1981 (2:nd-Mar-2025, 08:49:21)
