Trade Count:
( 0)
Threads: 4
Thanks Received: 0 in 0 posts
Thanks Given: 0
0
Car: Astra j
Sex: Male
Total Feedback: 0
Because with the cluster i didnt sort it out and the money wanted to be spend ive manage to buy all the parts for rear electrical windows
I`ve tried to find info and i saw that i need to have pins in the rear pillar like 1,10, 15 and the pins on fuse 20 from engine. I have them all. And now because i didnt find more infos..question is : if i have all the pins already fitted i need any extra cables from rear/front doors to bcm ?
Trade Count:
( 4)
Threads: 359
Thanks Received: 8 in 8 posts
Thanks Given: 1
73
Sex: Male
Total Feedback: 0
Trade Count:
( 0)
Threads: 4
Thanks Given: 0
0
Car: Astra j
Sex: Male
Total Feedback: 0
Yep..I saw it but I'm not really a schematic guy...
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
73
Sex: Male
Total Feedback: 0
If you have all the pins in the rear doors then it would be safe to say you have it all the way to the BCM etc.
Of course without seeing the car and looking I can't be 100% certain.
Trade Count:
( 0)
Threads: 4
Thanks Given: 0
0
Car: Astra j
Sex: Male
Total Feedback: 0
17:th-Jul-2019, 18:48:51
(This post was last modified: 17:th-Jul-2019, 18:50:00 by Maniacu.)
I've set them up..everything it's on position..but they are not working :|..I have light on switch but the motors dont work..
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
73
Sex: Male
Total Feedback: 0
Have you had a VCI request done & VCI code into the BCM?
Trade Count:
( 0)
Threads: 4
Thanks Given: 0
0
Car: Astra j
Sex: Male
Total Feedback: 0
No :|...I ask a friend for that but he told me for rear door it's not available..its only plug and play
Trade Count:
( 0)
Threads: 12
Thanks Given: 0
4
Car: Astra J SRI
Sex: Male
Total Feedback: 0
As far as I'm aware and @rusty2009 has done a few they will not work without a vci code and programming , pretty much nothing is plug a play now.
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
73
Sex: Male
Total Feedback: 0
No it's not the BCM need to be programmed via a VCI code to activate rear electric windows, without getting a VCI code from GM they will not work.
Rear power window retrofit Price Category B € 64,00 then there's the extra cost to request VCI code €42 then if GM don't come back in time there is another €42 fee to be able to program the VCI into the BCM.
Your need your security code for this and also after entering the VCI code to program the BCM you need to do a setup & config on the BCM.
Trade Count:
( 0)
Threads: 4
Thanks Given: 0
0
Car: Astra j
Sex: Male
Total Feedback: 0
Uhh so freaking expensive. It's any possible to activate the rear windows and light sensor in the same money ? I'm thinking to send it only one time for both of them
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
73
Sex: Male
Total Feedback: 0
Yes when the VCI is submitted for electric rear windows they need to type in the box.
Customer has fitted all parts & wiring for the the following.
CE1 + Moisture-sensitive Windscreen Wipers
TTW HEADLAMPS-AUTOMATIC ON-OFF
AER Rear power windows.
Can a VCI be provided for BCM & IPC.
Trade Count:
( 0)
Threads: 4
Thanks Given: 0
0
Car: Astra j
Sex: Male
Total Feedback: 0
Thank you for info. I will buy all the modules and fit them ..and then I will send the request one time for everything
Trade Count:
( 0)
Threads: 4
Thanks Given: 0
0
Car: Astra j
Sex: Male
Total Feedback: 0
Rusty2009 you have pm . Thank you
