j up cdti cold astra noise 2 start on
Astra J 2.0 cdti noise on cold start up
Hi Guys if anyone has a noise on cold start up that's sounds similar to a failing water pump but disappears after 10 seconds it could be the auxilary belt tensioner as I just replaced my belt and tensioner yesterday and what a difference. £70 fix so not too expensive just thought I would give everyone a wee heads up and the best way to confirm this is remove the auxilary belt and do a cold start and see if the noise has disappeared as well as feel for play in the pulleys as well.
I have a noise on cold start but only if the car has been stood for a couple days. it's like metal on metal.
Yeah mine sounded similar and it turned out to be the auxilary belt tensioner, if you know your not using it for a bit take the auxilary belt off and try starting it and see if the noise is gone, fairly easy to take the belt off anyway as that's my car now finally all good lol.
I also changed the auxilary belt as well since I had it off anyway.
  Astra J 2014 1.6 petrol, dashboard noise help Steve1982 0 1,067 9:th-Sep-2025, 08:39:49
  Astra J 2014. Electric static noise under dash Steve1982 0 994 8:th-Sep-2025, 21:22:49
  2010 Astra J - Cooling Fan issue Madal101_uk 3 4,067 19:th-Dec-2024, 22:04:08
Last Post: Madal101_uk
Chirping noise Zaf312 1 1,934 7:th-May-2024, 07:34:19
  1.7 cdti engine judder in 5th and 6th ScottN2211 0 3,269 21:st-Oct-2023, 16:27:48
Last Post: ScottN2211
  High pitched noise (Astra OPC J) maximame 0 7,006 24:th-Mar-2021, 08:34:13
Last Post: maximame
  Gear Knob issue (Automatic 2014 Astra GTC) DC23 1 8,196 22:nd-Feb-2021, 08:08:37
  Astra J. Can a tyre valve be replaced without replacing the TPMS? benawhile 2 7,893 5:th-Aug-2020, 12:33:14
Last Post: benawhile
  Astra GTC auto gear knob replacement Jayrich872001 12 31,794 22:nd-Jul-2020, 12:21:46
Last Post: DC23
  Astra J SRI 13 Plate - Radiator Fan Gavin1506 2 7,015 11:th-Jul-2020, 22:08:04
Last Post: Gavin1506
