s amp electrabizz c vxoc t
VXOC Electrabizz T&C's
Terms
All invoices must be paid in full before item/s are sent or vehicle leaves.
PayPal payments are accepted but paid as gift only, cash is preferred method of payment or bank transfer.
Due to buying parts for customers and being let down I will now be charging a deposit before any parts are ordered.
The deposit will cover the costs of any parts that I have to buy & will be non refundable should you change your mind.
Of course if I am able to use the parts on another job I will refund the money I receive, this maybe less than the deposit paid.
Any retrofits are done on the understanding that there maybe a VCI code needed, if GM refuse the VCI code all costs are still payable as with any retrofit there are many factors at play and GM have the final say and they can refuse.
If a retrofit doesn't need a VCI or there is a work around to the VCI again you can never fully say 100% it will work. Its a risk the customer takes when going ahead, again all costs are still payable.
Notes
Please note the VCI code is void after it has been entered into the vehicle, The VCI code is for your
own car & will not work on any other car.
Led Conversions Terms
All parts must be returned within 7 days via Royal mail next day by 1pm service or via a courier
service to an insured amount of £500 that will cover the cost of replacement parts if they are lost
or damaged.
If parts are not returned within 7 days a charge of £2.00 per day is payable unless agreed
beforehand. If parts returned do not match (I.E you return a non-chrome EPB button when I sent a
chrome) you will have to pay the cost to replace said part.
It has to be noted that LED's can fail & although all parts are fully tested prior to sending on
rare occasions a led may fail after testing or a dry solder joint may occur. If a LED fails the
item can be returned for a free repair but you are to cover your postage costs.
All LED's are covered for 12 months if after that time an LED fails there will be a small charge.
As this is a LED conversion done to your requirements any returns due to you changing your mind or
not liking the the colour you've chosen a surcharge will be payable @ 50%.
IPC upgrades
IPC upgrades are done at your own risk although I can check comparability so the IPC should work without issues on the rare occasion it may not work.
All costs are still payable.
jxstin_br (9:th-Sep-2024, 11:02:51)
