clutch |
Clutch
15:th-Jan-2017, 18:46:23
15:th-Jan-2017, 21:43:48
18:th-Jan-2017, 20:09:20
22:nd-Feb-2017, 21:00:58
23:rd-Feb-2017, 18:58:04
12:th-Jun-2017, 12:54:22
3:rd-Oct-2017, 19:27:43
my 2.0 cdti has developed a fault. when I accelerate in 5th and 6th , it gets to around 60-70 then sometimes its as if ive pressed the clutch in. the engine loses power and over revs like its not in gear?? If I let off for a few seconds then its normally ok. other times I have no problems?
4:th-Oct-2017, 11:02:25
(3:rd-Oct-2017, 19:27:43)r6sporty Wrote: Hi, are you aware of any other issues with the clutch? Had this in my old car. Was the start of my clutch going
2:nd-Mar-2018, 07:44:06
Got car in for service on Wednesday and mentioned this bulletin... they going to look into it. Cheers op ??
10:th-Mar-2018, 07:46:15
12:th-Jun-2018, 22:13:30
4:th-Jan-2020, 20:02:43
8:th-Jan-2021, 23:25:40
I've had the car for two years now, clutch hasn't gave me any bother other than the knocking sounds in second and third. I clearly don't have warranty anymore, but how would I go about bringing the bulletin to the attention of Vauxhall? Would they still fix it, the car is only 6 years old.
9:th-Jan-2021, 08:04:26
(8:th-Jan-2021, 23:25:40)14PGTC Wrote: Mine knocks in second and third gear, not so much in other gears. Also, if I was to accelerate and let off and put the clutch in, the whole car would shake. When you speak to them tell them you have a bulletin number. As to weather it would still be covered is something you would have to argue about with the dealership/ vauxhall. Be warned they are very good at wriggling out of things. Astra-J 2.0 CDTI S/S
Who read this thread? |
1 User(s) read this thread: |
emilalexandrubarb (19:th-Dec-2024, 20:59:32) |
