im new on this site and only just got my first astra what i would like help with is fitting an after market head unit as i do like my music
my first option would be to fit a sat nav unit like the alpine ine w990bt this requires a speed pulse signal for more accurate position on the unit where would i find the speed pulse wire to tap off??
i could forget sat nav and go with an alpine ive w585bt to fit both of these i will need to change the fascia is this a pig of a job or not to bad to do??
how much info will be lost on the top screen if i go ahead and do this install will the steering will controls cause problems the fascia is a connects2 model with all patch leads
i will also replacing the speakers and adding a sub are the door speakers a nightmare to do ? has anyone run a new loom for the door speaker or is it better to use existing loom??
thanks for any replys as im sure i will be asking more questions in the coming weeks as i progress
well here go's my install i have gone with a pioneer head unit avic f9880 dab
has all the bits i needed sat nav usb and so on
for the fascia im using connects2 parts
front speakers are jl c2 650 comps
rear speakers are jl c2 650 coax
sub is jl cp108
powered by a genesis profile 5 amp
so i have started on my install so far im not happy with the connects2 fascia as it seems a poor fit or does it need as they say a little fettling as where the ecoflex button is so seems to be pushing on the surround for the four line display this in-turn pushes the fascia away from the double din unit as well leaving a gap all the way round the unit
the unit is all the way forward in its bracket so should sit flush with the fascia but doesnt
please could some one help out on this one or should i contact connects2??
I found the facia to be a bit awkward to install at first, still have to sort of push down so it fits under the original display bit at the top as well even now, but does sit flush
yep D92 your right its a push down and up to get it to sit flush under the original surround for the 4 line display ....so im a happy bunny again
next daft question has anyone run a 4awg power cable thru the bulkhead?? ................if so where abouts did you run it as thats my next job to do as im nearly done with the first phase of the install
hi sorry i didnt get back sooner yes at the very top of the fascia it dips slightly but not enough for me to worry about
i have seen the grommet behind the glove box did you cut a hole in the grommet and reseal with mastic such as some dow corning or try to slide in with the loom
hi another question im going to run a new speaker loom from front to rear,has anyone done this i have seen the pictures and it looks a pig to do also what size cable did you use as im thinking of 12awg/14awg for the amount of power im running to the door speakers
too true no room what so ever behind unit but beside the glove box was just enough room to get that canbus converter in but the word tight is under stated....lol
