short shocks rear
Short rear shocks
Hopefully this is in the right section.
Right now the car sits like this on the back
It cannot go any lower as it's still on standard rear shocks, can anyone recommend any shorter shocks that will let it sit lower?
Cheers,
Dave.
2012 Astra J 2.0 cdti sri
That's way to low as It is haha
I would guess you will need coilovers, perhaps the shocks manufacturers 'GAZ' could make you a custom set.
To go even lower than that I would consider air ride suspension. Love the wheels btw
Nice wheel, what make and model is it??
Sendt fra min SM-G930F med Tapatalk
(5:th-Jan-2017, 18:17:25)mdruedal Wrote: Nice wheel, what make and model is it??
Is this the same Astra that hit a pot hole and pushed the front drivers strut up into the bonnet a few weeks back.
Yea, is same astra that hit pot hole haha all sorted now, 2 new top mounts later xD
Got the wheels from a chap in Wales for 150 and refurbished them gun metal grey
Its on air at the moment, that's it fully aired out, but it can go lower, just limited by the stock shocks.
I'll take a look at GAZ shocks, Cheers
  Changing rear brake discs Big Dave2 3 5,154 26:th-Jun-2020, 18:54:19
  Changing Rear Shock Absorbers. Astra-J Hatch. Replace or reuse bottom bolts? Big Dave2 5 12,413 22:nd-Jun-2020, 11:35:40
  Coil spring rear buy used or new caretaker 2 6,563 18:th-Oct-2017, 12:58:05
Last Post: caretaker
  Coil spring rear buy used or new caretaker 4 7,502 18:th-Oct-2017, 11:51:47
  Changing rear pads richje100 8 9,817 12:th-Jun-2017, 13:18:52
Last Post: Astra VXD
