jets windscreen washer
Windscreen washer jets
Does anyone know if these can be changed for the old type that you could adjust with a pin?
Reason is the drivers side always shoots over the car tried adjusting it I can't get any lower, I've also damaged it trying now.
I made a tool after googling it, identical to the one that Vauxhall sell but even that doesn't adjust them as well as I'd thought. It'd be interested to know if your idea is possible Rusty because its a downfall of the Astra J.
it all depends if they will fit in the hole on the scuttle panel it is the drivers side that seems to be badly positioned
i found if you take it out and then push it back in but not all the way it will sit lower and the jet will then hit the windscreen perfectly
I think the new ones are better for motorway driving but round town they are naff.
I did use the tool the dealers use problem is its down as far as it will go.
Tucpal I'd be more worried about it falling out it would just be luck.
no it holds fine been like that for a good while now works much better
it will sit just a few millimeters lower
and then it hits the window and does not fly over the top of the car
the adjuster just will not make the jet go low enough
[video=youtube;lB576YCiRiE]https://www.youtube.com/watch?v=lB576YCiRiE&list=FLWbz_u8PCLgYjRRIrE9CDKA&index=1[/video]
Nice one mate that looks better.
I have found these's http://www.ebay.co.uk/itm/VECTRA-C-Carav...27e2370f5b
Not so fussed about the heated part might give them ago once I have some spare funds.
This are from a H they may well fit too
http://www.ebay.co.uk/itm/VAUXHALL-ASTRA...257acc266b
they are worth a go rusty there is only one way to find out
Just ordered the H ones above so will let you know once the arrive
cool it is worth a go
The H ones fit but I need to get the deflector off so I can clip it in properly.
sounds promising then
nice, be good if it all works
Your not wrong, the washer jets are awful. I questioned whether they sprayed the windows at all!
Here is a video showing a few different angles for the J & H washer jets needs a little more refinement but overall I much prefer the H ones.
they certainly hit the window now
They are better
do the insignia ones fit? http://www.ebay.co.uk/itm/Genuine-Vauxha...234f8ef9e5
there the same as the astra j has already
I'll try to adjust them if didnt work ill get the h ones.
The new corsa has a triple jet each side better than the H, I find my J ones ok
have you got a link to them baz sounds interesting
i must say i have only really heard 5 door members about the direction of the jets
No link as only noticed today on my courtesy car.
Will have to do some searching
cheers mate
Had a look at the Corsa washers and don't think theyfit the Astra as there fitted to the bonnet
a much better location that is for sure
Unfortunately doesn't look like they can be fitted to our cars
  Replace windscreen washer bottle cap ma444 1 4,580 4:th-Oct-2020, 07:51:42
  front windscreen carlotwelding 7 7,396 5:th-Feb-2019, 21:35:09
  Windscreen Insurance sheppy1 10 10,398 24:th-Oct-2016, 16:04:12
Last Post: stigeye
  Washer jet upgrade / change? rbull51 1 6,722 27:th-Jul-2016, 22:58:36
  wheel locking nut washer grahamfromoldham 2 6,038 18:th-May-2016, 21:29:42
Last Post: grahamfromoldham
  Washer pump dead? richje100 18 24,164 27:th-Feb-2016, 19:54:40
Last Post: richje100
  Windscreen blackout Rusty2009 2 5,514 30:th-Oct-2014, 21:23:45
