light security
security light
LOOK AT POST 29 FOR THE HOW TO.........
i am just in the process of retro fitting this
i have had to add power and ground
and a switch to turn it on and off manually
but i am just waiting on a module to make it flash.
Good luck with that mate.
would be something I'd do if I didn't have the elite.
got a module on the way no idea if it will work
but i will find out soon
every thing works apart from it wont flash yet
Why not use a relay, so when ignition is on the light is off. Also working the other way, light on when ignition off.
yes that's a good idea its just finding one.
i need a circuit that will make the led flash
when i turn the switch on as the led does not flash
i found this any suggestions
MK111 ADJUSTABLE TIMER WITH 5A OUTPUT RELAY BLINKING LIGHT ELECTRONIC KIT | eBay
Aw mate let me know if you can get this going as id love to have this too :-)
i will keep this updated as it goes along
and a how to will follow.
tucpal Wrote:i need a circuit that will make the led flash
I can't see why that won't work should be fairly easy.
i will order it and see what happens.
that is what i have been looking for with no clicking sound from a relay
i will order it soon and put the results up here.
You can of course install flashing LEDs. You can buy them from Maplins.
yes but that will look fake
i want the factory look so it looks real.
although it will be fake.
but not that you would notice
I was thinking about placing the flashing LED under the dome on the speaker grill. If you get a bright one it should just look genuine.
you can do as long as it will fool the pro,s out there
who know what there looking for.
a genuine look is better but you can do what ever you want
the grill and sensor can be picked up for a £10 so its not expensive
and if that circuit works your looking at £16
and who would know the difference.
tried the relay circuit today no joy at all real bad kit
so its back to just adding a simple relay as i think this may be a better option
thats a bummer, but nice try mate
how hard can it be to make this thing flash
Tucpal do you not have the factory alarm on your car both my GTC and VXR have had the alarm with the lamp in the dash grill. It stays on on 1st lock and flashes on deadlock.
No don't have it
I may just take the internals out the led and put a flashing led inside it
You want a simple LED blinking?
KLICK
BR,
Jens
yes i agree i was trying to get the origanl SMD light to blink
but as you say the LED will be cheaper
i will just pull the origanl light unit apart and fit one in to it.
thank,s.
Ahhh there is still an SMD LED inside? Than it´s more easier .... just need a small circuit.
Let me have a look ....
Edit: Klick Just add the cables of your LED and the Power.
that looks better thank you.
Have you looked into this any more?
no been far too busy it is all wired up and working with switch
but i just have not got it too flash i will have to make the effort and get this done
i will come back to this soon
Could you do this on mine :-)
How To Retro fit the security LED Light
This how to covers How to Retro fit the LED Security light
So it looks like the origanl factory LED light.
First you need to get
1, Two rolls of 5 amp wire Red and Black
2, A Three way Switch
3, and a flashing LED.
4, A Piggy Back fuse and a extra 10 amp fuse.
5, Grill with the LED Dome.
STEP ONE...........
The First way i Tried was to Plug the origanl Connector
into the LED Dome on the Grill
The Grill will just Pull out of the Dash and the LED dome Just twists out from the Grill
You need to Remove the Console trim, Display trim, radio, and the Monitor
Behind the monitor you will find the Connector taped up to a Loom.
A How to can be found Here for trim removal radio etc
and the glove box removal.
http://www.vxoc.org.uk/forum/Thread-How-...en-removal
I Routed the loom Through the Speaker hole and Plugged it into the LED
But it would not Light up as there was no power
STEP TWO...........
So i took Power from the Glove box Fuse box
using a Piggy back Fuse in Position 16
I cut a Hole for a Switch in the Headlight Surround
and i took Ground from a Ground Point behind the Glove box
I then cut the Connector and Spliced the Power and Ground to the factory led.
Here is a Diagram of How to wire it all up.
Now the LED would Light up and Switch on and off now it had power
but it would not Flash So you could wire a flashing circuit to the LED To get it to work
But i just found it easier to get a flashing LED And put it inside the LED Dome.
STEP THREE............
Take the LED Dome and Push the Clips in on both side to Separate it Apart
Then take some Pliers and Pull the Circuit Board out
And Remove the white Blob from the Circuit Board and keep that to one side.
Place the Flashing LED into the Dome
and then push the white blob in side to hold the LED in place
the White Blob is Translucent and the LED will Shine thou it
then Pack the Dome with wadding and get the LED lined up so it Faces the Correct Position in the Dome
and then Refit it back Together so the Wires come out the Hole.
I then added a Connector to the wires on the LED
and the Wires in the Car for Power and Ground for the LED
To keep it all neat and tidy.
A How To on adding a Connector can be found Here.
http://www.vxoc.org.uk/forum/Thread-How-...-Connector
The LED will now flash when the switch is turned on
and go off when the switch is turned off.
And that is it you now have a Working Flashing Led
If you have the LED in the Correct Position it looks just like the Real Thing.
I am sure there are other ways to take Power with out adding a Switch
but that is what i went for if you have other ideas you are Welcome to add any info Here
Thanks and hope this helps.
As with all electrical how to,s we except no responsibility for any issues
and are carried out at your own risk. if the how to is follow correctly you will have no issues.
Hello.
I write english only a little.
If you put out the circuit of sensor led alarm, then the clima system don´t run.
show this video, is a new alternative to the led.   ;-)
https://www.youtube.com/watch?feature=pl...NgqGw9cxcA
and y can say you. where you can conect the led for no necessary switch. when you leave the car the led put on.
See you later.
Looks good
(21:st-Nov-2015, 04:33:37)Saxito@Tech Wrote: Hello.
See you later.
the alternative.
my own alternative...
this is the circuit schematic:
cables
Now we will conect into panel fuse box (driver fuse box); whith this conection the led flash when the car is whithout ignition, the same function that the 12v center conection socket. When the lighter has no voltage the led will flash. (don´t connect other circuits in this cables).
Put a nice led  wherever you want... example
now you can test the alarm led...
Please, if this site is no properly for the post message, any moderator put in the correct place...
thanks mate.
(7:th-Mar-2014, 19:02:34)tucpal Wrote: i need a circuit that will make the led flash
If your able to make circuits, a 555 timer with a circuit called a astable will work
Sent from my iPhone using tapatalk
Hi all, if anybody else needs this done you can get flashing LEDs that come with timers so you can set the sequence of flashes to suit from....ledpartsproducts
  how too AMBIENT LIGHT AROUND THE GEAR GATOR tucpal 165 150,032 15:th-Oct-2020, 06:59:05
  How-to led reverse light tucpal 23 33,229 18:th-Feb-2020, 08:26:05
  How-to Extra boot light Rusty2009 65 59,892 7:th-Jan-2019, 08:41:31
  How To remove the front courtesy light Rusty2009 6 17,014 16:th-Feb-2015, 01:35:07
no_name (9:th-Feb-2025, 18:49:34)
