chirping noise
Chirping noise
Sad
Hi all, I have noticed a high pitch chirping on my astra gtc 1.6 turbo, it only happens when the engine is near normal temperature, when I accelerate it's ok, once I slightly ease off the accelerator just a bit I get this chirping noise, nothing on acceleration though.does not happen whilst idling, pressing clutch pedal or brake does not alter the noise.had belt changed but no difference,the mechanic checked everything and he is baffled.the car runs and performs as it should, there are no oil or water leaks.the noise is so annoying, it's like I have 10 birds in engine
I would have the brakes checked could be a sticky calliper
  Astra J 2014 1.6 petrol, dashboard noise help Steve1982 0 1,114 9:th-Sep-2025, 08:39:49
  Astra J 2014. Electric static noise under dash Steve1982 0 1,035 8:th-Sep-2025, 21:22:49
  High pitched noise (Astra OPC J) maximame 0 7,073 24:th-Mar-2021, 08:34:13
Last Post: maximame
  Electrik brake noise!! blacknik 1 6,824 24:th-Feb-2020, 08:57:02
  Noise when clutch 1/4 depressed 2013 Astra J Galway11 0 10,751 27:th-Jun-2019, 22:40:04
Last Post: Galway11
  Strange noise from passenger side when driving slowly/stationary and just taking off irishastraowner 3 7,865 16:th-Mar-2019, 09:34:36
  Astra J 2.0 cdti noise on cold start up Iaintruten 3 10,755 17:th-Jan-2018, 17:26:31
Last Post: Iaintruten
  Water Noise Sloshing sheppy1 22 33,754 15:th-Oct-2016, 11:16:57
Last Post: andy2174
  Whirring noise richje100 13 24,327 20:th-Mar-2016, 15:32:00
Last Post: Jj0063
  Boot noise?? Anyone help me?? LukeAstra15 4 8,519 16:th-Feb-2016, 21:38:45
Last Post: bhalay207
dread123 (4:th-Mar-2026, 19:59:28)
