wiring heated seats
Heated seats wiring
Hello.
I have Astra J 2014 Excite.
I bought leather seats from Ebay. I mounted them in the car but I do not have any wiring for lumber support or for seat heating. There is no fuse box in the boot, HVAC control module doesn't have buttons for electric seats as well. Connecting the lumber support seems to be quite easy but the biggest problem wire the seats heating. How can I wire them doing in the cheapest possible way? If it is possible to wire it without the HVAC control module then I could mount different switches somewhere else. I also do not need 3 heating settings, one setting to turn the on for some time is enough. Bascially, I just want to be able to turn the on and off using a switch and that's it. Would it be possible to wire them any other way than they are normally wired?
Hi the wiring really should be done properly.
Where in the UK are you?
Perthshire
  Heated seat have no power briangorman 12 16,951 22:nd-Sep-2020, 12:53:22
Last Post: neshov
larustr (2:nd-Jan-2026, 03:10:53)
