sensors gtc parking retrofit front
Retrofit front parking sensors (GTC)
Hello! I've recently bought a 2014 Astra J Biturbo, it's only got the rear parking sensors, and therefor the distance is audible only. I am wondering what is involved in fitting front sensors, and having it programmed appropriately.
I have seen posts regarding retrofits, but can't seem to find one with info when you already have just the rears.
Any information is appreciated, many thanks, Pedro
Front bumper loom & sensors.
Custom made loom to go from battery to front bumper loom.
Sensor brackets.
New lower grill (depending on if any sensors go in grill).
New pdc module.
Hello, I recently installed front parking sensors for Astra J GTC, I will post a detailed video, until then I would like to help you.
If the front bumper is original, you can refer to the location of the sensor plates, I did not change the lower grille, I used the Plastic part with the license plate. (I haven't painted the sensors yet)
https://ibb.co/SB17mkB
In my vehicle's sensor, the connection cable (installation cable) for the front parking plot is partially broken, this cable goes to the front side to the cable bundle under the battery.
https://ibb.co/BtH8XNq
Do you have it in your own vehicle, check it first, I made the connection by pulling a cable from under the battery, in the original this cable comes together with the installation cable for the front fog lights, I will make the connection as soon as the original one.
https://ibb.co/DMRsx6H
After programming the module and programming the Yol b computer, everything works as it should.
https://ibb.co/hH43bWY
I will post a more detailed video later.
[Image: SB17mkB]
[Image: BtH8XNq]
[Image: DMRsx6H]
[Image: hH43bWY]
(27:th-May-2023, 23:46:17)M.Duman Wrote: Hello, I recently installed front parking sensors for Astra J GTC, I will post a detailed video, until then I would like to help you.
[Image: SB17mkB]
[Image: BtH8XNq]
[Image: DMRsx6H]
[Image: hH43bWY]
I am interested to do that aswell but under the battery are 2 connectors , which one is for parking sensors ?
My car doesn't have fog lights aswell so I would like to retrofit that aswell. I already fitted the complete front bumper with sensors and loom , I just need the loom between bumper and connector under battery tray
(12:th-Sep-2021, 15:36:40)Rusty2009 Wrote: Front bumper loom & sensors.
Sensor brackets.
New pdc module.
Hello. So if Retrofited already rear sensors for front sensors I need different pdc module ?
Why I don't see nothing on cluster just audible signal only ?
Thank you
  Retrofit Coolant and Wiper Fluid Sensors sheppy1 13 15,385 2:nd-May-2025, 17:32:02
Last Post: dellpiron
  Lowering springs identify front rear martinpe68 1 4,081 12:th-Sep-2021, 15:22:37
  parking sensor Qaranc 1 3,840 8:th-Feb-2021, 01:33:43
Last Post: loeb
  Front PDC wiring diagram milozic 1 8,065 2:nd-Feb-2021, 09:33:19
  Front suspension knock????? Sri~mike 10 14,839 22:nd-Dec-2020, 10:21:36
Last Post: M222RJF
  VXR Front Bumper onto a 5dr Bear 2 6,428 3:rd-Oct-2020, 11:48:59
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 6,472 12:th-Jul-2020, 07:37:10
  service parking assist and tpms not working kevinmcken1404 3 6,434 18:th-May-2020, 10:09:32
  Gtc 2017 1.4t 120 front brake disc size Nathan191210 2 8,204 25:th-Apr-2020, 07:41:05
  Can You Add Front Fogs to an Astra J? SAMW98SO 2 9,364 10:th-Apr-2020, 13:29:58
Last Post: SAMW98SO
5 User(s) read this thread:
Rusty2009 (19:th-Apr-2025, 19:19:22), husky (4:th-Apr-2026, 13:38:25), _Mita (19:th-Apr-2025, 10:00:49), Steve12 (21:st-Apr-2025, 21:16:24), dbk2ii (5:th-Sep-2025, 19:26:09)
