modules dab with bluetooth and 500 navi
Navi 500 with dab and bluetooth modules
Navi 500 patched to dvd800 so you get the 3d maps etc, has the latest map installed, comes the controls, colour screen. Also includes dab and Bluetooth modules, not pictured is the cable that links the screen to the stereo but this will be included also. looking for £125, willing to post at cost or you are welcome to collect.
[Image: ShzZ5A1qr4RQ5MC48]
Retrofitted, Navi950, Dab+, Astra k Rear camera & Towbar
Hi new on here have a 2012 Astra GTC would this fit and what else would need doing thanks
(4:th-Sep-2021, 16:41:11)geoffsnook Wrote: Hi new on here have a 2012 Astra GTC would this fit and what else would need doing thanks
Hi, yes it would, you would need to do a bit of wiring changes not hard to do. Thanks
Hi so what wires are needed i am interested where are you based
(5:th-Sep-2021, 09:30:50)geoffsnook Wrote: Hi so what wires are needed i am interested where are you based
Hi, here is a link to the post about the wiring changes
https://www.vxoc.org.uk/forum/Thread-cd4...500-wiring
 In short there are a few wires that need moving from one connector to another and adding of an extra wire for the screen to pin 43 on the radio connector if you don't already have that one in your car. you will need the gps aerial as well but you can just use a cheap £6 one off eBay if you don't want to go to the expense of the original shark fin, I have done this till I can get around to install my shark fin and it works perfect.
I am from Preston so a fair way from you, I can post it at cost if you still interested. Thanks
I already have the shark fin fitted as the car has dab fitted dont jnow if that makes a difference
Also is this divorced from the car and would i need any coding to get it to work in my car ?
(5:th-Sep-2021, 15:00:13)geoffsnook Wrote: I already have the shark fin fitted as the car has dab fitted dont jnow if that makes a difference
Hi, your shark fin will most likely be a dummy fitted as you have dab, and yes it will take your vin automatically when it is fitted as I have removed the old vin the correct way. you will not need to add the extra wire to pin 43 as it will be there with dab fitted.
 [Image: 20210904_121014.jpg]
So just an ariel and a bit of wiring is it how much will you take for it posted
And a mic i suppose
(5:th-Sep-2021, 19:08:15)geoffsnook Wrote: So just an ariel and a bit of wiring is it how much will you take for it posted
And a mic i suppose
Hi, I have sent you a pm. Thanks
Now sold
  bluetooth kit for sale frankie 11 14,430 14:th-Jan-2018, 17:24:00
Last Post: t8ylx
tanarchy (3:rd-Oct-2025, 15:12:21)
