astra j gtc bluetooth
BLUETOOTH.....
[Image: http://i179.photobucket.com/albums/w301/...68ca0b.jpg]
This is the Factory Retro Kit
For the CD400, and the  NAV,500,600,800.etc
[Image: http://i179.photobucket.com/albums/w301/...2yzrff.jpg]
It works Exactly the Same as Factory
because it is The Factory
Parts to retrofit bluetooth to astra j
Wanting to do this but not wanting to pay £225!!!
Wierd Bluetooth issues
Replaced my phone recently and now I can connect via Bluetooth but I'm unable to control the phone via Bluetooth nor am I able to access the address book.
The mrs phone works perfectly fine (this one did as well when it was her's. I get the car she gets the new phone)
Anyway phone in question is a Xperia Z her's is a Xperia Z1. The phone connects fine but when you try and dial a number the car shows dialling failed. Accessing the phone book it just says it is not available.
I've tried a
Bluetooth module
Bluetooth Unit
I've got the chance of buying a 2012 astra Bluetooth unit but wondered if I can fit it to my 2011 tourer or would it all need to be recoded? I've rang a guy about it locally but he didn't know lol.
Bluetooth Music
Is it possible (or even supported) to play music from my phone over Bluetooth using the factory fitted Bluetooth module?
I currently have a device that allows me to do it but never figured out if the car actually supports this.
Wanting to install bluetooth and upgrade CD400
As per the title
Next stage of upgrades to my car
As I have previously mentioned I was pretty hacked off that my Sri didnt come as standard with bluetooth (go figure that my wifes 63 plate £9K Kia has it!)
I dont want to undertake the work myself as I have very little patience and even less ability !
Been pricing up for bluetooth only install, metavoice system, circa £249 plus £100 fitting
This strikes me as pretty expensive for just having bluetooth
For an extra couple of hun
TPMS & Bluetooth
I've just bought a late 2013 gtc 2.0 diesel sri and was wondering if they all came with Bluetooth & TPMS, because both options are missing from the menus on mine. Tia
Bluetooth - what are my options with infinty sound
I have just bought an Astra GTC (2012) and it doesn't have bluetooth as part of the spec. I've done loads of searching but haven't been able to find an answer to my question.
My GTC has the CD400 HU, with Navi 600 and infinity sound system are there any options to fit bluetooth if it's an aftermarket system (Parrot, Bury etc.) any info on leads required?
Rich
Noise when using bluetooth for music
I have an eftermarket unit called RoadCommander. It´s like the well known Icebox and also have the big screen and replaces the CD400 unit.
The problem I have is, when using bluetooth for streaming music with my phone. There is a consistent noise. The noise doesn´t change when pressing accellerator pedal or driving at all. It´s consistent and very annoying to listen to. When you turn up the volume it follow´s up and becomes more annoying.
I don´t have AUX input otherwise I would definately b
