responding aux usb cd400 and not
CD400 usb and aux not responding
Hello guys, I recently bought this car, I had a previous Astra J GTC and I could listen to my music through aux just fine. On this one neither of usb and aux are working, I plug my cable but when I press Aux nothing happens, Bluetooth works just with calls. What should I do?
I would perhaps have a look making sure the wires are connected behind the ports.
You will only get calls on the Bluetooth no music streaming. You need a different head unit to do that.
So, I checked yesterday, because I also bought new ports, I thought that the old ones were potentially damaged. Still nothing is working, I could check behind the cd400 unit to see if those are connected but I am really thinking this has to do with software.
Does yours have the pdim module, I can check from reg. Maybe you head unit
I don't know that, but my reg is LR12AOK.
It's a module that fits under the dash on right hand side behind dab module that does usb and I think aux it's called portable device interface module.
so should I check and eventually get one? is that expensive?
  How To Fit Sub To CD400 Head Unit TUFFKNUX 138 166,656 20:th-May-2021, 09:19:58
Last Post: h4r7y
  CD400 Plus - what does the “Plus” Add? GordyC 9 20,073 12:th-Nov-2020, 10:41:15
  ad usb to cd400 Collie 5 6,499 9:th-Oct-2020, 16:56:47
Last Post: Collie
  GTC BT CD400+ ac1212 1 4,474 18:th-May-2020, 09:51:39
  CD400 buttons not working Android head unit install mephisto 4 11,380 27:th-Oct-2019, 17:30:00
Last Post: mephisto
  CD400 upgrade Astra vxr 2014 Nathan 6 7,902 22:nd-Oct-2019, 20:13:14
  Astra SRi CDTI VX Line - CD400 Upgrade options AdaKer 3 6,556 13:th-Aug-2019, 06:48:28
Last Post: Schiffers
  CD400 FAULTY kjohns80 2 5,267 7:th-May-2019, 11:05:06
Wink basic CD400 looking for more NEATH-LAD 2 6,461 8:th-Jan-2019, 16:23:12
  CD400, in meriva B, mid-speed can-bus off, wont allow can learn gazz292 3 11,991 28:th-Apr-2018, 08:34:44
adam@adamkimber.net (23:rd-Oct-2025, 16:50:56)
