chip key fob transponder replacement
key fob transponder chip replacement
Question
Hello all
I was attempting to change the key fob for my Astra J as the flip bit had become stuck and it looked simple enough. Unfortunately had a nightmare trying to open the original key and have ended up damaging the chip inside  I rang Vauxhall and they said it'd be look at around £200 (not going to do that).
Has anyone got any alternative solutions? Could I potentially use another Astra J keys chip and program it to my car?
Appreciate any help.
Thank you,
Param.
I believe the chips are single use. I think you van buy just the chip off ebay if you're OK with a soldering iron and there are some sellers that do a refurbished key but programming will be needed either way.
(2:nd-Dec-2020, 16:04:25)Jpbroad1970 Wrote: I believe the chips are single use. I think you van buy just the chip off ebay if you're OK with a soldering iron and there are some sellers that do a refurbished key but programming will be needed either way.
Thank you for the quick reply. Is it only Vauxhall that can do the programming? I had a quick look earlier and saw some of the chips on ebay so will have a good look later on. I don't believe it requires soldering as the replacement key shell I bought, has the chip sit inside and a fixing screw to secure it all.
You should be right there. Just make sure you get the right chip. They should be fitted on the board though even if just stuck
The chip is part of the board on the flip key it's not in the case it's self.
in terms of programming anyone with MDI & SPS can do it if they know what they are doing (all keys are needed) or even op-com can do it.
(7:th-Dec-2020, 08:17:28)Rusty2009 Wrote: The chip is part of the board on the flip key it's not in the case it's self.
Thanks Rusty2009. I have come across this website https://www.op-com.co.uk/store/c1/Featur...ducts.html - is this the one you're referring to? The best price I got from a reliable company was £100-115 for a replacement key.
The keyfob I bought was just the outer shell. I saw that on another post, you mentioned the Sundley replacement key fob - they're currently showing as not in stock. Do you have a link to any other ones that you would recommend?
Cheers,
Param.
Yes that's the recommend site to buy op-coms from.
In terms of the fob no I've only used the sundley ones a quick google found me this though, not sure what the shipping costs are though.
https://www.berrysmn.com/index.php?main_...s_id=10225
Thank you for finding that link.
  Replacement key JonathanLondon 1 4,587 1:st-May-2016, 22:21:01
  Indicator/Fog Light Replacement sheppy1 12 13,045 11:th-Mar-2015, 08:50:55
gemini6791 (4:th-May-2025, 18:52:51)
