KEY FOB
any where i can get a set of keys new and programed info needed
i am fed up with this key rattle now i need new ones as the spare is also broke
rusty do you think you can program a key to the car ??
found this but don't fancy the drive for a programed one
http://www.ebay.co.uk/itm/New-Vauxhall-O...27e7e57300
anyone know how much programing will be and will it be a vi
replacement key fob
I need to replace a key fob due to board damage, does anyone know a reliable place to order one from because I don't want to buy one that does not work properly thanks
key fob transponder chip replacement
Hello all
I was attempting to change the key fob for my Astra J as the flip bit had become stuck and it looked simple enough. Unfortunately had a nightmare trying to open the original key and have ended up damaging the chip inside  I rang Vauxhall and they said it'd be look at around £200 (not going to do that).
Has anyone got any alternative solutions? Could I potentially use another Astra J keys chip and program it to my car?
Appreciate any help.
Thank you,
Param.
