connector door pinout driver
Driver door connector pinout
Hi, i was searching for the Driver door connector pinout.
Can anyone help me?
Here you go see the 2 attached files.
.pdf   X500 Driver Door Harness to Body Harness (DWF).pdf (Size: 54.81 KB / Downloads: 68)
.pdf   X500 Driver Door Harness to Body Harness (without DWF).pdf (Size: 42.89 KB / Downloads: 53)
Thumbs Up
(4:th-Jul-2019, 18:45:20)Rusty2009 Wrote: Here you go see the 2 attached files.
Thanks! Very helpfull!
I retrofited the door looms for rear electrical Windows.
Since i replaced the Driver door loom, the locking for the door doesnt work anymore.
Could this happend that the AER isnt programmed yet?
I'm looking at this pinout and I can see that 34 is used for LED Ambient Lighting Control 1.
Any chance that this pin isn't working? The door light is very dim.
I had the same behavior when I set up the LED around the gear gator. I was supposed to use pins 9 and 10 for LED Ambient Lighting Control 1, but the light was very dim, so I ended up using pins 7 and 8 as I've written in https://www.vxoc.org.uk/forum/Thread-how...0#pid51570
Any chance to setup power in this pin 34?
I checked on the body side and it's there.
P.S. I didn't have any ambient lights, to begin with, now I added foldable wing mirrors and swapped out the complete door installation and the new one came with the LED connector, so I expected that the door light will be plug and play. But now they are very dim and the weirdest thing is the door speakers don't work at the moment, so that will need checking as well.
The new mirrors work tho Smile
The gear lighting there has always been 2 options of wiring it if pins 9 & 10 don't work then 7 & 8 it is that's the same even on UK cars.
Although pins 7 & 8 are used if EPB is fitted.
In terms of the doors try pin 26 for power to the LED
  Navi600 usb connector Reddevil2412 3 5,900 18:th-Aug-2020, 07:10:54
  Airbag connector BishopSRB 5 8,211 26:th-Jan-2019, 22:37:33
Last Post: BishopSRB
  ECO button connector diagram (start/stop) aurega 1 10,975 4:th-Nov-2018, 15:06:37
6 User(s) read this thread:
obsidian (10:th-Sep-2025, 10:58:08), jas7c5-2008 (10:th-Mar-2026, 14:02:49), hookme (7:th-Jun-2025, 21:21:31), AstraJErik (17:th-Jul-2025, 09:12:59), lollone (31:st-Oct-2025, 17:01:23), Michael997 (27:th-Feb-2026, 22:11:47)
