sump plugs
sump plugs
Hi now I have changed a lot of oil in my time, and have always renewed the sump plug washer or o ring, but just lately I have come across always renew the sump plug ? when doing an oil change, on web sites and tv shows, any ideas where this is coming from or opinions on the subject, me I think I will stick with renewing just the washer/o ring
(27:th-Apr-2020, 14:14:42)andyp Wrote: Hi now I have changed a lot of oil in my time, and have always renewed the sump plug washer or o ring, but just lately I have come across always renew the sump plug ? when doing an oil change, on web sites and tv shows, any ideas where this is coming from or opinions on the subject, me I think I will stick with renewing just the washer/o ring
Hey andy, ive akways been in the team of renew sump plugs and washers. But i guess when your thinking of businesses that may not go this extra step as it is another thimg for them try to sell to customers who probably dont like to spend any.more on their cars to keep it running. What tv shows have you seen where they are against this? Would be interesting see what they say not to do it.
Hi it was on an episode of fifth gear jimmy devil modifying a vxr corsa (fitting a bigger turbo), not got a problem doing this just wondered why it has just started to be advised ?
I always change sump plug every 2nd service.
At work we change them every service, it forms part of the service kit.
when I worked for v/w (a few years ago now!) we always changed the sump plugs, (as do most garages now)
we often found cars with stripped or damaged threads in the sump, these were mostly on cars that that had the original plug re-used a few times.
hence the need to replace then regularly
  3 out of 4 glow plugs Euroshopper 1 4,214 2:nd-Nov-2020, 22:10:39
  Spark plugs Mspencer 1 4,305 7:th-Jan-2018, 23:12:43
Last Post: Iaintruten
  Any one recognise these spark plugs? Zcubed 2 7,308 7:th-Jul-2016, 08:19:47
Last Post: Zcubed
  spark plugs JJ-Yorks 1 4,545 20:th-Feb-2016, 11:47:37
  Water Plugs sheppy1 11 11,319 28:th-Jan-2016, 23:19:25
  glow plugs tucpal 6 8,306 25:th-Jan-2016, 11:03:48
