plugs? any recognise spark these one
Any one recognise these spark plugs?
I've been having a few engine hiccups with my Astra J 1.4T.
I have replaced the coil pack as I heard the  original was prone to causing problems.
Anyway today I took the spark plugs out to take a look and was surprised to find these.
They are labelled as GM Champion RC10MCC R6
They were fitted by a main dealer in January 2016 as part of the service.
Does anyone recognise these as being the correct type?
Have they fitted the wrong type?
I thought they were supposed to be IFR7X-7G, GM 5557026.
Thanks for your help!
they did use gm stamped champion plugs but they were changed for ngk at some point
think they should be 55576026 but that may depend on year of manufacture
rusty may check for you
(6:th-Jul-2016, 22:07:48)tucpal Wrote: they did use gm stamped champion plugs but they were changed for ngk at some point
Thanks for the info.
Just a bit concerned they're not the right ones.
Think I'll fit the correct set.
  3 out of 4 glow plugs Euroshopper 1 4,202 2:nd-Nov-2020, 22:10:39
  sump plugs andyp 5 5,571 29:th-Apr-2020, 22:25:57
  Spark plugs Mspencer 1 4,283 7:th-Jan-2018, 23:12:43
Last Post: Iaintruten
  spark plugs JJ-Yorks 1 4,529 20:th-Feb-2016, 11:47:37
  Water Plugs sheppy1 11 11,284 28:th-Jan-2016, 23:19:25
  glow plugs tucpal 6 8,290 25:th-Jan-2016, 11:03:48
