4:th-Jul-2019, 18:11:32
Hi, i was searching for the Driver door connector pinout.
Can anyone help me?
Can anyone help me?
| connector door pinout driver |
Can anyone help me?
4:th-Jul-2019, 18:45:20
Here you go see the 2 attached files.
7:th-Jul-2019, 01:13:40
I retrofited the door looms for rear electrical Windows.
Since i replaced the Driver door loom, the locking for the door doesnt work anymore. Could this happend that the AER isnt programmed yet?
10:th-Nov-2020, 10:14:02
I'm looking at this pinout and I can see that 34 is used for LED Ambient Lighting Control 1.
Any chance that this pin isn't working? The door light is very dim. I had the same behavior when I set up the LED around the gear gator. I was supposed to use pins 9 and 10 for LED Ambient Lighting Control 1, but the light was very dim, so I ended up using pins 7 and 8 as I've written in https://www.vxoc.org.uk/forum/Thread-how...0#pid51570 Any chance to setup power in this pin 34? I checked on the body side and it's there. P.S. I didn't have any ambient lights, to begin with, now I added foldable wing mirrors and swapped out the complete door installation and the new one came with the LED connector, so I expected that the door light will be plug and play. But now they are very dim and the weirdest thing is the door speakers don't work at the moment, so that will need checking as well. The new mirrors work tho
14:th-Nov-2020, 09:53:25
The gear lighting there has always been 2 options of wiring it if pins 9 & 10 don't work then 7 & 8 it is that's the same even on UK cars.
Although pins 7 & 8 are used if EPB is fitted. In terms of the doors try pin 26 for power to the LED Astra-J 2.0 CDTI S/S
| Navi600 usb connector | Reddevil2412 | 3 | 5,774 |
18:th-Aug-2020, 07:10:54 Last Post: Rusty2009 |
| Airbag connector | BishopSRB | 5 | 8,044 |
26:th-Jan-2019, 22:37:33 Last Post: BishopSRB |
| ECO button connector diagram (start/stop) | aurega | 1 | 10,854 |
4:th-Nov-2018, 15:06:37 Last Post: Rusty2009 |
| Who read this thread? |
| 5 User(s) read this thread: |
| obsidian (10:th-Sep-2025, 10:58:08), jas7c5-2008 (Yesterday, 17:59:19), hookme (7:th-Jun-2025, 21:21:31), AstraJErik (17:th-Jul-2025, 09:12:59), lollone (31:st-Oct-2025, 17:01:23) |
