power amplifier wires
wires power amplifier
hello guys,
(sorry for my english)
i want to install a subwoofer on my astra J but i did not find any information to run wire from battery inside the car...
someone could help me please ?
regards
alex.
Come though the passenger footwell where all the other wires go through (on rhd cars)
Put the fuse for the amp as close to the battery as possible.
thanks for answer...im LHD car Smile . but i remove glove box...i did not see any hole to ge through.
i removed the glove box...I did not see any hole to pass a cable ... there is foam everywhere :]
Have a look in the driver footwell you can't miss the big load of cables coming in through the bulkhead.
Wink
thanks rusty, sorry i dont have a very good english so i translated "bulkhead" but i think the word i french did not mean the correct word you think.
so i put a picture maybe it's better :Smile
https://i.ibb.co/0Y8CZwf/astra-opc-interieur.jpg
EDIT :
you talking behind pedals or under floor ?
[edit] i removed the battery and behind the cooling tank i found this...  think i can make a hole and go
[Image: proxy.php?request=http%3A%2F%2Fi38.servi...704b7de2c4]
Sorry firewall may have been a better word to use.
Yes that's it go through on the right the single big one.
I don't know if this translates into the correct French wording.
Désolé, pare-feu a peut-être été un meilleur mot à utiliser.
Oui, ça passe à droite le plus gros.
Je ne sais pas si cela se traduit par le libellé français correct.
(20:th-Feb-2019, 10:47:06)Rusty2009 Wrote: Sorry firewall may have been a better word to use.
ok understand big one on the right Smile
ok done, battery removed, coolant tank removed, I made a hole with a screwdriver and its done :Smile
thanks !
  Steering wheel angle, esp, power Steering smoky-jr 3 7,486 6:th-Jun-2021, 18:23:26
Last Post: jeniferbitcoin71
  Power, performance and looks RVernon 1 4,668 16:th-Jul-2019, 13:45:07
  Lacking Power - What can I check everson38 3 6,120 10:th-Jul-2019, 10:44:50
Information No power Taylor89 7 7,659 4:th-Jun-2019, 20:27:03
  1.6 cdti power loss ihastings 25 32,423 19:th-Oct-2018, 07:37:42
  Help diagnosing loss of power Thebatfink 9 16,400 6:th-Jul-2016, 07:23:31
  GAIN MORE POWER ASTRA J 2.0 CDTI ECOFLEX ELITE 165BHP Bturbo123 44 63,407 3:rd-Jun-2016, 14:14:02
  USB Port Power Boost sheppy1 6 10,442 10:th-May-2015, 23:12:40
  Power Consumption sheppy1 3 6,812 6:th-Apr-2015, 16:26:02
  Connects2 interface box constant power. Rusty2009 14 17,867 18:th-Nov-2014, 18:07:33
