amp sub
sub amp
im thinking of fitting a sub/amp, the main power wire needs to connect to the battery (+)
can any one tell me if there is any where in side the car I can connect to.
Power from battery and ground can connect to a ground point in the rear.
(29:th-Oct-2018, 17:26:20)Rusty2009 Wrote: Power from battery and ground can connect to a ground point in the rear.
cheers for your reply, but is there a way through the bulkhead.
Yes come though where all the other wires go through.
Put the fuse for the amp as close to the battery as possible.
When I fitted mine I had to cut the bolt and replace it, new bolt and nut can be brought from halfords.
