to cluster a new bigger better upgrade and ligth how display
HOW TO UPGRADE TO A NEW CLUSTER BIGGER DISPLAY AND BETTER LIGTH
Hi everyone in this amazing forum, i would like to open this thread about how to change from my actual speedometer to a more recent one with bigger display and better inside light.
A step by step with pictures would help me and everyone who's interested in this!
My car is a Astra 1.4 petrol and i already have the better speedometer for the same model as mine!
So anyone that could help adding information to solve and enlighten us all would be amazing!!
It's not as simple as just getting another set.
There's a lot more to it than that.
There are only 2-3 people on this forum that know how its done properly and we've had to work it all out hence I offer the service to do it and it can be done via the post or in person.
Nobody would give me any help when I started doing it I've had to work it out for myself.
THANKS RUSTY.
I've read a post about this, but i cant find it now, and i think that was you that post it, and you said that that Astras J before 2012 they don't need any coding or something.. am i wrong?
(7:th-Aug-2018, 17:26:17)Skemess Wrote: THANKS RUSTY.
They all need some form of coding (there is a common misconception that pre 2012 don't need VCI codes) but this totally depends on what you are doing.
ok, so sorry about my ignorance what is VCI coding? and i only want to get the new speedometer with the bigger display and lights u know...
I have the op-com if its needed to get more info in the display if that helps.
VCI is vehicle configuration index.
Op-com can turn on extra menus in the IPC yes. But to get it working in your car needs more than op-com.
So what do i need then put this to work? or could you find that post about this? i cant find it. thanks.
You won't find any info as I've already said there is 2-3 of us that know how to do it.
If you want it doing It can be done by myself or @Jpbroad1970 for a fee.
OK.. so how much will it cost me then? and how long will it take for u to do it? thanks
https://www.vxoc.org.uk/forum/Thread-Price-list
can astra k speedo be fitted to my 2013 astra j & would i get all the functions with my navi 600
(10:th-Aug-2018, 01:09:09)thefukingod Wrote: can astra k speedo be fitted to my 2013 astra j & would i get all the functions with my navi 600
Anything is pretty much possible with enough time and effort and money but I can assure you that it is not straight forward in any way. It appears the system talks differently
That is very true John & I have been working on the insignia IPC, although it's still very much a WIP.
Im here again Rusty.. so how much cost the to unlock or fix to do my new ICP? and how long will it take?
Im in Cambridge area, and where do i need to sent it?
thanks Rusty.
Hi Rusty.. maybe you been busy, I dont wana rush you but you didn't answer me yet! About the price and how long will it take and where to send? Thanks
(13:th-Aug-2018, 22:29:42)Skemess Wrote: Hi Rusty.. maybe you been busy, I dont wana rush you but you didn't answer me yet! About the price and how long will it take and where to send? Thanks
John posted the link to my price list for you. I need your REG or VIN number as I need to check the spec of your car and then look at the options available that match your spec.
(9:th-Aug-2018, 20:55:15)Jpbroad1970 Wrote: https://www.vxoc.org.uk/forum/Thread-Price-list
HI RUSTY, my reg is SL10 UYX THANKS again
(16:th-Aug-2018, 20:35:42)Skemess Wrote: HI RUSTY,  my reg is SL10 UYX THANKS again
PM on way.
(7:th-Aug-2018, 01:36:29)Skemess Wrote: Hi everyone in this amazing forum, i would like to open this thread about how to change from my actual speedometer to a more recent one with bigger display and better inside light.
hi, I don't know if you have your clocks done yet, but  had mine done by rusty2009
he`s a top man he knows what he talking about.
marky79 dateline='[url=tel:1535409098' Wrote: 1535409098[/url]']
Skemess dateline='[url=tel:1533602189' Wrote: 1533602189[/url]']
Hello can this be done? I am very interested.
Can anyone do this for me?
  how to upgrade the NAV600 to a NAV900. tucpal 317 330,939 9:th-Sep-2021, 16:24:59
Last Post: gparini13
  Navi 600 to 900 upgrade problem! Help needed ASAP! bh03an 5 19,981 29:th-Aug-2020, 20:34:20
Last Post: iamwalsh
  How-to remove Instrument Cluster (IPC) Rusty2009 24 59,474 23:rd-Jul-2020, 11:21:25
Last Post: scrooge
  Swap astra J dash display chrisscruton 6 13,025 25:th-Mar-2019, 10:16:12
Last Post: chrisscruton
  Upgrade to alloy door pins tucpal 7 22,140 5:th-Sep-2017, 12:24:44
Last Post: Padster
8 User(s) read this thread:
Rusty2009 (19:th-Jan-2026, 10:06:08), Morpheus75 (28:th-May-2025, 09:56:52), carl_howells (22:nd-Feb-2025, 23:27:52), obsidian (20:th-Feb-2025, 17:31:30), orhunnx (19:th-Feb-2025, 03:53:29), Buashei (4:th-Feb-2026, 11:46:22), dbk2ii (22:nd-Oct-2025, 21:23:19), N0madd_builds (3:rd-Dec-2025, 14:55:46)
