sports tourer j reverse astra for camera
reverse camera for Astra J Sports tourer
Hi to all,
has anyone fitted a reversing camera to their Sports tourer?
I bought one on amazon that was supposed to fit but it did not.
Any hints or links to a camera that will fit the license plate lighting slot?
Any help is appreciated!
I don't recall seeing an aftermarket camera for the tourer. IIRC the light is slightly longer then GTC/hatchback.
Last one I fitted to an estate I used factory kit £157 plus vat. camera, loom and new switch in handle
Hi would you have the part numbers & would they work with a navi 600
try 13391275 fits 2012 - 2015
see this https://www.opel-accessories.com/opel_ao...a/13391275
13391275 REAR VIEW CAMERA, KIT (CD600) (NAVI600) (NAVI650) (NAVI900) (NAVI950) £152.00
Does this need activating with vci code ?
officially yes
I was curious if this factory kit also does the guidelines, and do they move with along with the steering movement? Smile
Retrofitted:
I believe so
(31:st-Jul-2018, 18:37:15)Garpenlov Wrote: I was curious if this factory kit also does the guidelines, and do they move with along with the steering movement? Smile
There are 2 VCI codes 1 is free without guidelines the other is €35.00 for guidelines (I find most of the time they give you guidelines on the free one just depends who doing it GM end)
The lines do move with the steering wheel yes.
Sorry messed that up see above lol
Thanks for the info folks Smile
Retrofitted:
  Sports Tourer DAB+ on Android Headunit MikeyP247 2 3,324 2:nd-Nov-2019, 17:11:28
  CD400 upgrade Astra vxr 2014 Nathan 6 5,787 22:nd-Oct-2019, 20:13:14
  Astra SRi CDTI VX Line - CD400 Upgrade options AdaKer 3 4,682 13:th-Aug-2019, 06:48:28
Last Post: Schiffers
  How to Install Android Head Unit + Wireless Reverse Camera sheppy1 64 44,459 9:th-Jan-2019, 15:07:53
Last Post: Shorty5
  Need usb connection or din 1 on Astra J Elite benawhile 6 6,900 3:rd-Sep-2018, 12:56:28
  my 1st Astra J Audio Help CD400 NEATH-LAD 8 9,795 1:st-Jul-2017, 08:01:59
Last Post: srea064
  single din in astra j micko 4 5,384 8:th-Apr-2017, 21:34:34
  External fm/dab antenna in Astra J mdruedal 5 7,912 27:th-Oct-2016, 21:55:56
Last Post: mdruedal
