xenon afl retrofit
AFL / Xenon retrofit
OK I await YOUR RESPONSE WITH ANXIETY
ok sorry its taken me all day
ok so there is no way to do it via op com you will need to get an mdi plugged on
Tomorrow I'll go to the dealership to get me calibrate the AFL with MDI.
Hi guys I'm pretty new in this discussion. First of all congratulation Rusty for the nice job. I have an Opel/Vauxhall Insignia of July 2009. I found two bi xeno headlight from second hand market. Do you think would be possible to make the same modification? Does the BCM need reprogramming to let AFL properly work?
thanks
(2:nd-Jul-2018, 11:51:16)gonnelfi Wrote: Hi guys I'm pretty new in this discussion. First of all congratulation Rusty for the nice job. I have an Opel/Vauxhall Insignia of July 2009. I found two bi xeno headlight from second hand market. Do you think would be possible to make the same modification? Does the BCM need reprogramming to let AFL properly work?
thanks
Officially it can't be done but there is a work around which I know to make it possible.
Thank you.
I have all the wiring diagram to adapt the system. looks very similar to what you did for your Astra J. I doubt to reprogramming, because I do not how GM can still support the SPS VCI.
thanks
(3:rd-Jul-2018, 11:53:10)gonnelfi Wrote: Thank you.
thanks
GM won't support it, I got mine through just before a big change. there is a way round it but I wouldn't tell anyone how to get around it in public or private.
  Digital cluster (virtual cockpit) retrofit milozic 5 12,731 30:th-Apr-2023, 19:51:49
Last Post: milozic
  Navi950 DAB+ retrofit help milozic 1 8,339 8:th-Sep-2021, 21:22:59
  Steering wheel remote control retrofit EricMod 32 39,161 10:th-Jul-2021, 12:37:38
Last Post: carolef1984
  Lane departure retrofit? toxx 3 8,974 22:nd-Feb-2021, 09:16:29
  Auto Lights and Bluetooth Retrofit kalum0101 5 13,845 2:nd-Aug-2020, 13:48:24
Last Post: kalum0101
  Navi 950 retrofit to Buick Encore vibalt 3 13,427 21:st-Jul-2020, 19:02:30
  Retrofit 12v sockets Rusty2009 7 23,361 15:th-Mar-2019, 09:21:09
  Front camera retrofit for Lane departure and traffic sign assist Rusty2009 124 138,491 2:nd-Feb-2019, 11:54:01
  Simple Retro Fit Way for Xenon syscleaner 9 21,798 11:th-Feb-2017, 08:34:22
  DAB Retrofit info Turner_SRi 36 39,830 8:th-Dec-2016, 13:49:02
Last Post: Jerry
jas7c5-2008 (30:th-Dec-2025, 20:05:05)
