fault codes sensor abs
ABS sensor/ fault codes
Thumbs Up
Had service ESP warning light come on, the TC light and ABS light came on.
I've had the codes read, one was drivers side front ABS wheel speed sensor and the other was for ABS pump.
Got both cleared and esp warning came back on straight away from leaving the garage, I have changed the sensor now and had 4 hours of warning light free driving today [Image: thumbsup.png].
However the ESP warning has come back on, I've not had it back to have the codes cleared since the sensor was changed, is it required or am I looking at something else being the issue as I doubt another sensor has gone.
Cheers,
Will
I had to replace the hub on mine behind the hub is a metal ring this broke and damaged the hub and sensor.
(8:th-Jun-2018, 07:49:24)Rusty2009 Wrote: I had to replace the hub on mine behind the hub is a metal ring this broke and damaged the hub and sensor.
that could be it, the old sensor was a bit chewed up from the looks of it.
Would the offending metal ring be included in a wheel hub kit usually ?
No it’s separate.
But I was advised afterwards not to fit the washer as it will only brake again & it’s not really needed.
Can anyone recommend a good, reasonably price fault code reader. Abs sensor has gone. Need to find out which one.
http://www.op-com.co.uk/store/c1/Featured_Products.html Don't buy cheaper from ebay or other sellers.
Cheers lad.
Hi pal I have a 2013 Astra I had the esp light on after plugging in computer it stated front left wheel speed sensor I changed this and it’s back on with same fault do you have any ideas
As rusty says in post 2 wheel bearing or it could be wiring fault.
  Exhaust Gas Temperature Sensor P2084 bagnallman 4 13,078 2:nd-Sep-2021, 08:17:51
Last Post: geoffsnook
  Astra J 1.7CDTi - Boost sensor location for Chipbox jason.dexter 8 15,056 4:th-Feb-2019, 14:40:25
Last Post: rlievens
  Gtc 1.6 cdti 136 fuel rail sensor location? harrykelly9 3 9,308 11:th-Nov-2018, 08:55:56
  Tpms sensor. Htid 5 9,017 21:st-Feb-2018, 20:43:06
Last Post: Htid
  Fault code DTC P2458 Starie 6 13,640 20:th-Jul-2016, 17:06:38
Last Post: Starie
