to sound gtc loud good astra 0cdti and 2 how
How to Astra gtc 2.0cdti sound loud and good
Hi I m new here but I wanted to know how could I make my Astra gtc 2.0 cdti sound Sporty and loud not to loud tho
And still being able to pass the mot
Removing the DPF is a little more tricky these days with the MOT laws changing.
It all depends what you want to spend, and if you want to take the risk. You could smash it out and hope the MOT place won’t notice, which they probably will. Or, get a straight pipe produced to replace the DPF and keep hold of your DPF should you ever need it again.
I’m not 100% clear on the new MOT laws, so you’re best reading up on it before you do anything with the DPF.
A start could be having the back box/ silencer removed. This will make it a bit louder and a bit gruntyer and the DPF will remain in place.
  Astra 2011 2.0 Fault Codes - P0087 & P0399 - Cylinder 1 Pressure Circuit Malfunction coalfield 2 10,000 5:th-Oct-2020, 23:21:12
Last Post: coalfield
  Astra j sport settings change!! blacknik 5 10,642 13:th-Dec-2018, 20:17:47
  Astra j wheel nut thread sizes Azza1807 3 13,224 16:th-Sep-2016, 20:25:31
Last Post: stigeye
  Astra J Wheel PCD Chrissyf 1 10,336 5:th-Sep-2016, 06:52:36
  owners manuals. astra j, astra gtc tucpal 2 18,633 18:th-Feb-2015, 08:31:35
  online work shop Manuel for the astra j tucpal 0 16,668 27:th-Feb-2014, 18:18:41
Rusty2009 (27:th-Dec-2025, 18:24:47)
