5:th-Apr-2018, 16:11:52
Are there different sat nav antennas? i mean i imagine they will be different for the different cars, but do they all work the same?
I pulled this one off an astra in the scrappers, not sure what radio it had as it was gone, but the antenna has 3 connections... all those fakra types... so i presume it's got fm, dab and sat nav?
i pulled the antenna wires out best i could... was weird how they were all three together till the drivers seat, then one of them split off and went up under the instrument panel (with a conector about where the accelerator pedal is) then it carried on up a bit, then across the instrument loom and into the radio area,
the other 2 cables went left, across the front of the seat area, then into the gear shift space, where there was a 2 pole connector, then they went up into the radio space... annoyingly those 2 cables had been cut by the monkey who removed the radio (and the ends left in the car, so he prolly cut a tie wrap and sliced the antenna cables)
Anyhoo, i'm slowly amassing the parts for a navi950 system in my meriva B, got the colour screen and meriva specific mount, and now hopefully an antenna.... if i can find another car with those 2 short lengths of cable from the join by the gear stick,
but i think the navi950 has 2 antenna connections.. having dab built in?
so do i need to look for a combiner for the fm and dab parts of the antenna... or should i look for a better antenna?
Oh, and anyone got a navi950 main unit and button panel to sell me cheap
