complete sat nav system
Sat nav Update info
Sat Nav update discs.
When purchased they are sold as Hardware and Software.
The hardware is the update of the Sat Nav, A New Firmware version.
The Software is the Map Program itself.
How to install a Map Update (The manual isn't clear on this and no instructions are given with the disc)
1. Insert the New Map CD into the CD player.
2. The screen will show that there's an update for the firmware.
3. Click Install.
4. It will ask if you wish to over write the Flash in the memory, click okay to do
How to install Sat Nav to a safe location
This little gadget seems too obvious for me to post it online and technically it isn't a 'how to' guide. However, I'm sure there are drivers on this forum who may just have overlooked this idea so I'm posting it in case it helps someone.
Instead of having your TomTom stuck on the windscreen in your face, there is a 'gooseneck' available, some made my TomTom themselves and others that are after market. Mine is an after market one and may do the job better because as far as I know it is slightl
Hev - Replies:
Updating Bi Turbo Sat nav
I think my sat nav needs updating. How do I go about that?
Is it a trip to the dealer?
Cheers peeps
Kris - Replies:
@Tucpal @hev - sorry mate i couldnt reply to the other thread but i think the only way to update the 950 is to take it in for a software update which apparantley they only do 2-3 times a year as the navi 950 doesnt have an sd card that you can access. If it uses one its probably built in or behind it which you'd have to take it all apart to get too.
gazz292 - Replies:
sat nav antennas
Are there different sat nav antennas? i mean i imagine they will be different for the different cars, but do they all work the same?
[attachment=976]
I pulled this one off an astra in the scrappers, not sure what radio it had as it was gone, but the antenna has 3 connections... all those fakra types... so i presume it's got fm, dab and sat nav?
[attachment=977]
i pulled the antenna wires out best i could... was weird how they were all three together till the drivers seat, then o
Qaranc - Replies:
portable sat nav
have got a garmin sat nav and i want to place it on the right below the a pillar any suggestions on how to secure it the shape of the dash is not helping thanks
Slakky - Replies:
Sat Nav issue
Hi all new member, as anyone got any ideas on how to remove the red line thru the GPS symbol, done the Nav600 to 900 hoping it would help but it’s still on there
Sat nav unit, from insignia? Not fully working?
I bought my 2013 Gtc 2.0l about a month ago. Absolutely love it but the previous owner must of fit what I thought was an aftermarket satnav/touchscreen unit but apparently it’s from an insignia? The touchscreen works fine and the satnav does too and SOME of the speakers work... but the center console buttons don’t work, not a single one of them do anything? The only way I can control the volume is on the steering wheel buttons (which all work fine) the speakers in the doors don’t work and
