cdti valve dump
Cdti dump valve
Hi guys, correct me if I'm wrong but does the cdti have a dump valve? I hear the whoosh sound when changing 1st, 2nd and 3rd gears and wondered if you could mod it to make it louder?
I must say I've not heard it on my 2.0 and TBH I don't know if they have a dump valve or not.
They don't have a dump valve but I believe they have a recirc valve. As for making it louder not sure if you can. A cone filter might do the trick.
Cone filter on mine you could hear more of a sucking noise, but tbh that was about it, maybe try putting a bigger airbox to turbo pipe and a better cold air feed, should do the trick!
I tried a cone filter on my cdti and it was horrible sounded like darth vadar, took it off after 1 day
  VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN caretaker 3 3,916 21:st-Oct-2024, 18:22:15
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 7,066 12:th-Sep-2021, 15:24:05
  2.0 CDTi Auto Gearbox Oil Change Dennis S 0 3,878 13:th-Aug-2021, 14:29:25
Last Post: Dennis S
  Astra J GTC 2.0 CDTI A20 DTH Stage 1 Remap - Wayside Performance M222RJF 8 10,528 11:th-Sep-2020, 20:55:21
Last Post: badger64
Sad Astra 1.7 CDTI fuel quality problem klajdi 0 3,885 10:th-Sep-2020, 12:10:05
Last Post: klajdi
  Fuel Shutoff Valve NuttySqurill 1 3,368 12:th-Aug-2020, 07:58:08
  1.6 cdti 5 door exhaust tip? h4r7y 1 4,336 17:th-Jul-2020, 06:47:38
  1.6 cdti engine reliability Loddy Jeff 7 19,418 9:th-Jul-2020, 22:04:47
Last Post: Loddy Jeff
  Which wheels and tires Astra J 1.6 CDTi 110hp _Mita 1 5,282 31:st-Jan-2020, 09:38:19
Last Post: _Mita
  High Idle 1.7 cdti Cossie 0 4,209 26:th-Aug-2019, 07:06:32
Last Post: Cossie
