12v aux rear
Rear 12v aux
Hello, I've got a 2012 se and want to fit a rear 12 v aux socket, I've had a look in the boot and there is a fuse box on the N/S how easy is it to wire one to this, I'm useless with electrics so nice and easy please?
It doesn't work off the rear board it works off the glove-box one.
We have a how-to here.
https://www.vxoc.org.uk/forum/Thread-How...12v-socket
If you mean by rear the boot that again runs from the front but only on the estate model, so hatchbacks don't have the wiring in place.
(26:th-Jul-2017, 07:02:48)Rusty2009 Wrote: It doesn't work off the rear board it works off the glove-box one.
I've looked in the user manual and it says empty fuse holder 30 in the rear load compartment is for rear power socket, couldn't I just put a spade conector into it for live and a inline fuse and earth it to  the body.
That is for the boot 12v socket.
You would have to see if there is even connections in the fuse-board where the fuse would go.
If there is then yes you could.
Big Grin
(27:th-Jul-2017, 07:22:47)Rusty2009 Wrote: That is for the boot 12v socket.
Sorry I meant to fit it in the boot and not the rear
  Rear light power problem phlyer 1 5,237 21:st-Dec-2023, 08:27:49
  Rear Fuse Box leeso 3 6,429 15:th-Nov-2019, 08:19:15
Last Post: tcmtuning
  Rear light out but works again with headlights Willcbrbikeboy 6 10,227 14:th-Jan-2019, 09:43:44
Last Post: vocky
  Washer Motor stopped (front & rear) neilll 3 10,091 6:th-Dec-2016, 14:03:31
Last Post: stigeye
  Rear rooflight GTC Hummelshøj 4 7,839 10:th-Jul-2016, 09:32:28
