Retrofit 12v sockets
Going to try and and retro fit a 12v socket in rear and also one in boot.
I have the wiring diagrams and the adding a rear will be easy adding the boot will take a little more time as the fuse it uses isn't used so getting pin out and wire gauge is annoying.
I got a couple of 12v sockets out of a pug 307 and 206 estate as they have cover on them.
How to Rear 12v socket
How-to rear 12v socket.
The first thing you want to check is the fuse board behind the glove box for fuse 6
[Image: https://www.vxoc.org.uk/Images/rusty/Rea...cket/1.JPG]
If you have fuse 6 the remove the fuse board (just pinch the two tabs at the top and pull towards you.
You need to look for Pin 24 and 30 I could only get a pic of 24 but 30 i
Rear 12v aux
Hello, I've got a 2012 se and want to fit a rear 12 v aux socket, I've had a look in the boot and there is a fuse box on the N/S how easy is it to wire one to this, I'm useless with electrics so nice and easy please?
perm 12v near mirror
Save me fishing about fruitlessly, anyone know if there is a permanent live near the mirror or overhead light?
I want to wire my dash cam from it.
Thanks!
