climate sensor control
Climate control sensor
Hello, does any one know where the climate control sensor for Astra J sports tourer 2011 is located? Something strange is going on with my climate control. I have to set it up to 26 to start having some slightly heated air inside. No errors on the computer. Thank you in advance for the help.
Mines the same.
its in the dash somewhere I'll look it up on TIS later
I found that mine might have a problem after taking a ride on my friend Mazda 6. His climate control was set to 22 and it was blowing quite good warm air. And on mine on 22 it's blowing cold. But now it appears it might be not only mine like. Thank you for this Rusty
I have to have mine set at 26 before warm air comes out.
Here's the image only info I could on sensors. 32 & 37 are the sensors
[Image: Hvac%20view.png]
  Clean DPF - O2 sensor location Henhead78 1 221 24:th-Apr-2026, 17:31:05
  Brake pedal sensor learn. Richiew1986 0 3,032 22:nd-Jul-2021, 16:53:31
Last Post: Richiew1986
  parking sensor Qaranc 1 3,901 8:th-Feb-2021, 01:33:43
Last Post: loeb
  Coolant light coming on when coolant is full (new sensor and no leaks) baffling me! Brasseyebaby 3 8,180 2:nd-Feb-2021, 21:12:47
  Glowplugs with pressure sensor or not Euroshopper 3 5,768 2:nd-Nov-2020, 16:01:21
  Heating / climate control iandy66 2 4,046 14:th-Sep-2020, 18:11:08
Last Post: iandy66
  DPF pressure sensor richardhmorgan1 3 7,055 24:th-Sep-2019, 20:08:31
Last Post: Saunter
  Parking sensor Mspencer 2 5,139 19:th-Dec-2017, 17:34:12
  Cruise control not working raimon 10 30,748 27:th-Nov-2017, 12:33:46
Last Post: AlanMac
  A/C pressure sensor location scotchmist67 0 4,346 2:nd-Aug-2017, 10:04:34
Last Post: scotchmist67
