z8083 - Replies:
climate control
Hello guys i have dual zone climate on my car when i bought it in climate control i had temperature zone at start where i choose if i want single or dual mode but after update i lost that function does anyone about this .
Zcubed - Replies:
Blower vents Dual Zone Climate question?
I'm having problems with what I think is my air direction blower motor that controls which vent or vents the air gets directed to.
Would be grateful for anyone who has a similar setup, to answer this question:
If you manually set the air direction to your feet only, do you get a lot, a little or none out of the windscreen or front vents, or does it ONLY come out on your feet?
Thanks in advance
Climate control sensor
Hello, does any one know where the climate control sensor for Astra J sports tourer 2011 is located? Something strange is going on with my climate control. I have to set it up to 26 to start having some slightly heated air inside. No errors on the computer. Thank you in advance for the help.
iandy66 - Replies:
Heating / climate control
I currently have standard heating controls on my GTC J.
Is it possible to fit the climate control? Found a switch panel on eBay is anything else required? I’m guessing programming is needed.
Thanks in advance
Ian.
