led lights numberplate
Led numberplate lights
Does anyone know if I have to have the resistors with the leds or can I just put an led bulb straight in? On the Astra gtc?
number plate bulbs need resistors if you are going to use led's
Hi guys,
Jumping into this thread so i don't open another for the same question. I have a '13 Astra J OPC, and i fitted LEDs on plate license lights, but i get bulb check error. Tried a number of LEDs for which the sellers advertised as CANBUS but they still throw error. I got a electronic tester and measured 100 ohms on one set of LEDs (without power to them), and 175 ohms for another set (with more LEDs and lens at the top).
Any idea how to get them working or what resistance should i have for the LEDs ? Cannot find a replacement set with full casing and i really don't want to use a big resistor which will get hot. As per my calculations, at 5W , the resistance of the circuit when powered should be around 30 ohms with a normal bulb. (501 halogen), which is a lot less than my LEDs with 100 and 175 ohms without power.
  Astra j no indicator lights? Any help pls Winston 1 9,796 29:th-Mar-2020, 09:43:57
  DRL and rear lights Jimobob 1 8,399 25:th-Jun-2019, 15:23:09
  Auto lights stuck on main beam? umognog 3 12,207 12:th-Nov-2017, 08:06:59
  led lights THOMAS123 1 9,775 28:th-Oct-2017, 07:20:50
  Foot well lights (live location) ronnierae 1 11,164 26:th-Apr-2017, 07:15:03
  Changing day-time running lights GarethMyers14 6 10,751 15:th-Apr-2017, 22:09:35
  GM LED Tail lights McGill2009 20 20,818 30:th-Mar-2017, 08:39:39
Last Post: thebigman1106
  Lights alarm stevedemp23 3 6,455 13:th-Mar-2017, 18:47:21
Last Post: stevedemp23
  tail lights McGill2009 2 5,797 7:th-Nov-2016, 11:29:18
Last Post: cornishtaz
  Footwell lights tommyboy1289 2 6,232 21:st-May-2016, 06:02:12
Last Post: tommyboy1289
