22:nd-Jan-2017, 13:00:05
Good Morning (Just!)
I recall reading somewhere that early Astra's have a problem with the boot seams failing but I can't locate it.
Reason for asking is my Astra has water in the footwell which was partly due to the high level brake light, which is now changed.
However I am still getting water in the boot after rain and it appears to be coming out the seam on the boot floor at the back. I suspect this as when I wiped the water away I could see a drop of water re-emerging through the seam.
So I've got myself some potential options;
1. I'm trying a penetrating leak and crack finder which should cure it.
2. Get some seam sealer and clean the outside behind the bumper and cover the affected areas.
3. As I have only had the car 9 days I send it back to the dealership for them to sort?
Car is 2011 2.0l CDTi SE
Thanks,
Ben.
Thanks,
Ben.
