to sharkfin fm gps dab use anubody? am for
Use SharkFin for GPS/DAB to GPS/FM/AM anubody?
I have purchased the oem sharkfin for GPS/DAB as I have the normal aerial on the my GTC now.
I have bought duppel Fakra connections and extra wires with fakra male/female and connection for GPS aerial on headunit as I have RoadCommander, like Icebox etc., unit instead of the factory CD400. And I want the factory look.
I know on factoty fit navi cars, the FM/AM aeriel was built in the rear tailgate. But that is not an option to make or is it?
[Image: _35_zpsnxfdvuri.jpg]
Has anybody tried to use the DAB side of the aerial for FM/AM signal, and use GPS wire for GPS as I am tired of the GPS block that came with the unit that is glued to the windscreen.
That shark fin is only GPS.
Vauxhall never did did GPS/DAB sharkfin.
(13:th-Nov-2016, 13:49:06)Rusty2009 Wrote: That shark fin is only GPS.
Both wires is for GPS?
One wire is for GPS, second wire is for phone I found. But could I use phone wire for FM/AM, It should make no matter, should it..
Totally different frequency.
I use an aftermarket Sharkfin that does GPS, AM/FM & DAB don't be shocked by the price it's very good and works never had one drop out.
http://www.carcommunications.co.uk/dabmo...anc7677940
Is it possible to retrofit the factory radio signal in the rear tailgate as when the car has factory fit Navi.
I most say that 150£ for an aerial is a lot of money.
yes i did it on my old astra j
https://www.vxoc.org.uk/forum/Thread-DAB...the-CD-400
https://www.vxoc.org.uk/forum/Thread-DAB...00-and-600
