aerial replacing
Replacing Aerial
Hi, I have seen a couple of pictures showing some of the headlining being pulled down from around the tailgate for aerial removal. How far do you need to go to get the aerial out as I pulled along the whole of the tailgate edge and it was still too tight to gain propper access or even see the aerial base nut. The FM aerial connector seemed to be fixed to the roof somehow, so it looks as though I will have to remove quite a bit of the roof lining, unless I am missing something?
I just don't want to knacker the lining  Shrug
Don't be shy is what I'd say. And don't be alarmed by the crease in the lining when you pull it down.
It's hard to explain by typing but you need to pull it down so it's nearly touching the parcel shelf, but to do that you need to make sure it's come out of the rear quarter window panels.... If that makes sense
Cheers for that mate  Thumbs
Where did you connect your red power wire to when you did yours, front fuse box, rear fuse box, nearest live feed?
I have just noticed that the replacement aerial (FM) has a male hirschmann connector and the car I believe has a female fakra (once old aerial disconnected) so now have to source a female hirschmann to male fakra connector, they seem few and far between after a quick search.
I ran mine down the offside and tapped into the front power socket. You neec the purple cable.
As for the connector, I'm not sure
I could run a new FM aerial lead from new aerial to the 300Di and then connect from the 300di to CD400 but would prefer to keep the original FM cable in place, still connected to the CD400 as I can connect the 300Di to CD400 via Aux In. My preference is keeping it original FM and connecting via Aux In, I have to run the new dab aerial to the front anyway so no biggie if I have to add the FM cable too.
I suppose I could source a din female to fakra female (I believe the CD400 is male fakra) and connect the new FM aerial that way if I can't get hold of the hirschmann to fakra connector.
All done now, took power from the rear fuse box for the aerial, pushed the fm/ dab cables down the roof lining to the front, down the windscreen pillar and across to the head unit. Wasn't too difficult, it's more of a worry that you might break something along the way as there's no way of doing it subtly. Everything at least seems to be running smoothly...
[Image: 092bcb3ddb572dd4956abf53a851df86.png]
very good work
  Replacing door check strap robk999 5 10,465 7:th-Feb-2019, 21:27:33
  Subby Aerial CRNeo 2 6,160 11:th-May-2015, 17:36:52
Last Post: WhelanUK
  Aerial Cameron UK 9 12,449 14:th-Jun-2014, 15:17:26
Last Post: J1ODYA
