remove windscreen the casing sensor on
Remove the sensor casing on the windscreen
How much space is there inside the cover for the rain and camera behind the rear view mirror? Also is there any tricks for removing it?
[Image: cameracase.jpg]
I've got a dash board camera and was thinking of fitting the GPS unit in side the cover.
John
haha I fitted the highbeam / camera mirror and cover myself ready for the AFL, to be honest mate the best place I found for the GPS is the passenger side wing.
To get it off it just pulls down and apart. be careful though I can't get the cover to sit back tight anymore I need to pad the fixing point out with blue tack or something.
Cheers. I'll have another look then. As there is a long cable for the GPS so I might try else where as it saves having to hide the bunched up cable. Would little foam pads work better for you. They are used to separate pains of glass.
Thats a good idea Thanks, where I have my GPS to I can't get any pics but if you take the glove box out and drop the fuse board then stick your hand towards the wing and feel along you will find where to put it.
  Fuels Temperature sensor Nuko-san 9 20,839 10:th-May-2025, 09:32:21
  How to remove sun visor Astra J GTC. MCG1983 2 5,694 21:st-Sep-2020, 10:52:43
Last Post: MCG1983
  Sensor Box Window Tint sheppy1 1 8,000 29:th-Jul-2016, 16:10:25
  Remove GTC bumper insert pope30 3 7,364 20:th-Jun-2015, 17:23:35
Last Post: pope30
  Light sensor warning! Alienbv 9 13,133 12:th-Mar-2015, 15:30:35
  AFL level sensor recalibration cornishtaz 4 11,240 30:th-Apr-2014, 08:38:20
  How to remove reflectors from the rear bumper??. Cameron UK 3 9,519 9:th-Apr-2014, 07:53:23
Last Post: Cameron UK
