cdti 7 the owners 1 for
For the 1.7 cdti owners
I would like to know that what sort of miles your getting out of a full tank..
Im struggling to get 400 miles out of the full tank and my mate at work has a 2.0 and get around 600miles out it and I'm wondering if i have an issue i don't know about.
A 1.7 has to work harder to pull almost 2ton of car than the 2.0.
I get about 430-450 from a full tank driving around town and commuting. No motorway driving tho
Its power to weight. Smaller engine x heavy car = More fuel burnt
It's only 1.4ton, not quite 2ton lol.
I never run mine empty but today for example my range shows as 78 miles left and I've covered 443 miles on this tank & il fill up tomorrow.
oh right, I thought I should be getting more then I am. As the range when I fill up is just over 500, so now Im wondering if I have a problem somewhere then?
(18:th-Jul-2015, 00:24:55)Jj0063 Wrote: It's only 1.4ton, not quite 2ton lol.
Depends on spec extras engine mine is almost 2ton.
(18:th-Jul-2015, 06:31:55)Lewis6317 Wrote: oh right, I thought I should be getting more then I am. As the range when I fill up is just over 500, so now Im wondering if I have a problem somewhere then?
Have you done your own MPG test or are just reading the screen?
Remember there are a few different 1.7 CDTI engines 110bhp 125bhp 135bhp start stop etc and driving style boy racer or saint driving around town and motorway will also differ MPG as said you are best to work your own MPG out and try to better it by working out if altering your driving style may improve it
Agreed with Tucpal.
I changed my driving style and my mpg and miles per tank shot up from 450 to 600+.
The best thing to do is keep the revs below 2000rpm where possible and try to make your way through the gears as quick as possible without ragging it.
It's difficult because you have to concentrate on all of your gear changes etc.
I get around 550 out of mine and it's mainly motorway driving
Sent from my OnePlusOne
  VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN caretaker 3 4,110 21:st-Oct-2024, 18:22:15
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 7,286 12:th-Sep-2021, 15:24:05
  2.0 CDTi Auto Gearbox Oil Change Dennis S 0 3,980 13:th-Aug-2021, 14:29:25
Last Post: Dennis S
  Astra J GTC 2.0 CDTI A20 DTH Stage 1 Remap - Wayside Performance M222RJF 8 10,775 11:th-Sep-2020, 20:55:21
Last Post: badger64
Sad Astra 1.7 CDTI fuel quality problem klajdi 0 3,980 10:th-Sep-2020, 12:10:05
Last Post: klajdi
  1.6 cdti 5 door exhaust tip? h4r7y 1 4,432 17:th-Jul-2020, 06:47:38
  1.6 cdti engine reliability Loddy Jeff 7 20,141 9:th-Jul-2020, 22:04:47
Last Post: Loddy Jeff
  Which wheels and tires Astra J 1.6 CDTi 110hp _Mita 1 5,479 31:st-Jan-2020, 09:38:19
Last Post: _Mita
  High Idle 1.7 cdti Cossie 0 4,287 26:th-Aug-2019, 07:06:32
Last Post: Cossie
  2.0 CDTi SVS/Limp mode :( hooper 8 11,963 14:th-Jul-2019, 06:18:48
Last Post: Dennis S
Users browsing this thread:
